Adding indicator to Bennett trim tabs...
Live2Dive
I have Bennett trim tabs. Can an indicator be added after the fact? Any guess on cost?
Yes it can be done. I was gonna do it on my boat but splicing into the hydraulics where they recomended seemed like more trouble than it was worth. If I remember right about 2 hundred bucks, I'd say 3 to be safe w/install.
The indicators do not require splicing, and they certainly don't work off the hydralics - it is an electrical connection that plugs directly into the computer module.
You have to replace the top caps of the hydraulic rams.
In my Pea sized brain I can imagine a sliding device attached to some part of the Tab that moves full scale.
So we use this device to move a 'Timing fence' through a Photo-Transister pair.
Or a Rotary device to cause a Transister to function from a different location as the tab moves.
Or another way of telling some logic the Tab's location might be to use a Fiber Optic light, connected to the moving part of the Tab.
That's how your weather vane transmit's it's direction to the Weather system. So you can bet your boots this add-on for your trim tab's has already been invented.
I'd start with the Mfg.
The question asked about an "indicator". That would be Bennett's "Trimindicator Angle Indicator", which does indeed tap into the hydraulic cylinders. Here's the instructions off the Bennett site I visit, certaintly doesn't work off a computer:
http://www.bennetttrimtabs.com/TPIINSTALLa.pdf
However, for $300 versus the $200 for the above you can buy the "ATC Control System", that does work off a "computer", and eliminates messing with the lines - but it's not an "indicator":
http://www.bennetttrimtabs.com/onlineatc.htm
Bennett will soon have out a much improved tab position indicator that's combined with the rocker switches. It was supposed to be introduced last month so I think we can expect it pretty soon.
they make a rocker switch that replaces the one is there now. The new unit will show where the tabs are set at. I thought this unit hooked right back up to the wires that are connected now.
art
It is Lenco that makes the plug in module and not Bennet. The indicator is built right in with the switches. Won't work on Bennet tabs.
art
art
The one I mentioned looks a lot like the Lenco unit. A lot like it!
I've seen a photo.
