Additional Gray Water Tank
jrcinnh
I boat on Lake Winnipesaukee, NH, so no gray water can be discharged. The Searay answer to this, is to plumb all gray water to the shower sump and then pump it into the Vacu-flush holding tank. Since that tank is only 27 gallons, it fills pretty fast if we use the shower.
I want to add another tank and there's room for a 25+ gallon tank.
I'm thinking that moving the gray water hose to the new tank would be pretty easy. How do I empty the new tank? I could add another deck pump out fitting. But is there a way to connect the tanks so everything comes out the existing pump-out fitting?
