Also look at www dot soundown dot com in their installation accessoriy section. There are aluminum pins and washer/clips that I have used to hold the material in palce along with the contact cement.
That foam is usually very heavy. Use the spray contact cement, and the pins/washers if at all possible. Be sure to clean the surfaces well first so the cement has something solid to stick to.
