Advice on Replacing Sole....
Live2Dive
Our carpet is looking pretty worn at this point. Just spent the weekend at TrawlerFest, and saw a lot of beautiful boats with teak and holly sole. Anyone here have experience replacing their sole? I was thinking of replacing the salon and pilothouse carpet with teak and holly, and recarpeting the staterooms. Any recommendations?
Thanks for you input.
Mark,
There have been a few threads on teak and holly. If I am not mistaken, some of the members have used "faux" material and are very pleased with the results, from the aethestic to the reduced maintenance.
I went with a recycled product from "PlasTeak". It's extremely durable and I have been very pleased so far. Mine was installed by a pro. Looks like I could have done it myself though.
This is NOT my boat:
go to plasteak.com
Most "teak and holly" soles are only a very thin vineer. if you do make one, I suggest a thinned clear epoxy as a first coat, and then several coats of a polyurethan varnish. A real teak and holly sole, is actually made of strips of teak, with the white wood (can be holly, magnolia or maple) raised about 3/32 (give or take) proud of the wider teak planks. This give s grip as the boat heels or rolls. There is a satisfaction of laying a real teak and holly sole--and it will last the life time of the boat--but it is not cheap or easy.
Bob Austin
A lot of high end boats are using Amtico now in new construction. A few happy owners over on the Hatteras Owners Forum. Apparently easy to install and almost maintenance free. I'd like to add it a it some point myself (well the wife more than me, actually..). I have the name of a good guy down S.FL way you may want to talk to. We looked into a variety of options and like Amtico the best. We have a real T&H sole on the aft deck, requires too much TLC for my taste. We did refinish it with Epithanes Wood Gloss a year ago and that has held up pretty nicely.
George
Hatteras 56MY
Boston Whaler 130 Sport (not in need of a T&H sole)
NUTEAK is a synthetic. They were at a local boat show and got several orders. I'm considering it.
nuteak.com
Look at Amtico.
I just put in my galley and 2 heads. Great stuff, used on Hatts, Vikings, yachts, etc......
I saw an older 50 something Hatt SF redone entirely with Amtico, came out great.
Originally posted by Robyns Nest
Look at Amtico.
Did you purchase the marine amtico or just the regular 'flagship' amtico?
Where did you purchase from? Cost? Did you use the two part adhesive?
I purchased directly from Ocean Yachts. They were running a special clearance last year, $4 sq ft., normally runs $6. Used the one part Amtico glue, easy to apply, trowel on, wait until it tacks up, start putting down the strips.
Regular Amtico, looks great, will hold up to anything.
Robyns Nest - do you have pics of your install or what it looks like now?
Our carpet in the salon (and the master) is light-colored, we put a throw rug down, which looks pretty nice and is comfy on the feet, but I'm not a fan of carpet. We have wood in the galley which is BEAUTIFUL...if I could find a match for that or else something that is complementary that would be good. I like the idea of wood (or at least the appearance of wood) throughout the boat, the bathroom does have a neat patterned/textured floor (a wave design, non-skid, it's pretty cool). Boat is a '99 Carver Mariner 350, here's what our galley floor looks like (it's pretty thick, maybe 3/8") and you can see the carpet in the master.
on my boat the underlying floors are easily removed after picking up the carpet. solid floors would make access more difficult.
I went with hardwood flooring for just the opposite reason; it was EASIER than carpet. The deck is covered, and the hatches are covered, separately.
A couple more questions...
1. Do you have any issues with the material pulling up or creaking? The install instructions specificallly talk about the product being installed in a 'climate controlled' environment where the temperature never drops below 60 degrees F.
2. What product color is that? Teak? How did you get the holly strips between them? Were they part of the teak strip or was that separate? On Amtico's web site, I found no installations that showed what you have in the picture.
Thanks.
Amtico makes a great product, we installed it in the Univ of TN baseball stadium players areas, more durable and lower maintenance than hardwood. The climiate control / enviro conditions is humidity affecting the adhesive, it's not moisture tolerant. At lower temps, the floor covering itself loses some of it's flexibility, but shouldn't be an issue. The installation temps need to be over 60 so the product can acclimate and you want that flexibility to ensure tight joints when butting the planks together.
Amtico is indeed used by many builders these days incl hatteras. The only issue retrofitting is that the floor surface must be smooth..
That said it s hard to beat carpet for price and ease of install.
Pascal is correct with floor smoothness, ANY type of resillient floor covering will telegraph imperfections in the substrate. Cleanliness is second with dirt, dust and/ or grit acting as bond breakers between your adhesive and substrate.
Thanks.
No issues with the cold so far. I've been on the boat now when it's cold and no issues. Remember that you are installing on smooth flat surfaces.
Amtico's web site is very poor. I still can't believe that they paid someone to create it. Totally useless. The color is teak and the holly strips are separate strips cut by machine.
Pascal, I hear you there (regarding carpet)...have you replaced the carpet on the boat yourself or did you have it done? I've never messed with carpet, other than ripping it up at my house (to be replaced with tile). I'll admit that I've never installed flooring of any type, it scares the daylights out of me...but I won't think twice about getting out the wrenches and tearing into a nuts/bolts/mechanical project, so I supposed I could learn...LOL
