Hi to all of you
This spring when I made my first ride, I have notice that there is water in the bilge after a day boating, I am suspecting that the motor wasn't properly winterized even if I had paid for the job.
Can it be the block that is cracked or only the expansion plug that pop off, is there anyway to pin point the problem and what can expect money wise in either case.
The motor in a Mercruiser 6.2 MPI 2001 with 370 hours
Thank you
Thank you
