Several years ago our 16,000 BTU Marine Air reverse cycle unit crapped out. It fell apart when I started looking into why it quit (rust). So I went with a new Mermaid of the same size because it was all stainless. I don't think Marine Air had an all stainless model at that time.
I like the Mermaid unit, but it came with a way-too-small raw water pump, and the unit would regularly switch itself into the heat mode. Many times after visiting friends on the other side of the marina, the boat was 120 degrees inside when we returned. Since replacing Mermaid's cheap little pump with a larger March (big bucks), that problem seems to have gone.
Its funny that I replaced an old Marine Air with a Mermaid because the Marine Air rusted (not just the pan, but a lot of the fan and support pieces, too) and Davida is replacing an old Mermaid for the same reason. Maybe this shows that quality of marine parts are gradually improving!
