Here is other valuable info from the website:
What equipment and software do I need?
[AIS base station Setup]
A typical base AIS station is shown on the picture above. Obtain and connect to your PC an AIS receiver with an external VHF antenna and send the collected data through your Internet connection. In detail:
1. You need an AIS receiver.
You may buy one from a local marine electronics shop or you may order one from an online shop.
We have tested the following devices with our software, with similar results:
* COMAR SLR200 dual channel (~500 €) www.parissinos.gr
* EasyAIS – dual channel (~300 €) www.easyais.com
* SaNav AIS-2 – dual channel (~350 €) www.navtronics.gr, www.sanav.com
* Smart Radio SR162 – dual channel (~400 €) or SR161 – single channel (~180 €) smartradio.diytrade.com
If you are not sure whether your location is suitable for AIS data reception and thus you do not want to buy a device, we can lend you an AIS receiver unit, to try it. You will have to return it to us within one month.
2. You need a VHF antenna.
Any marine VHF antenna is suitable for AIS reception. A 5/8 type antenna seems to be better for a base station (see 1st picture). For a little better results you may get an high-gain VHF antenna (e.g. a 3 x 5/8 aerial) or an antenna specially designed for AIS, such as the "Shakespeare 396-1-AIS". Install the antenna at the highest possible point of your building.
If you feel you can build your own handcrafted antenna, then you have many better options. Since in most cases the sea is not located around us but towards one direction, it is a very good idea to construct a directional (Yagi) antenna pointing to the sea (see 2nd picture). You can calculate the length of the antenna elements at this site:
http://www.k7mem.150m.com/Electronic_Notebook/antennas/yagi_vhf.html (Remember to enter frequency 162 MHz). You may also try a custom made "Collinear" AIS antenna.
: A 5/8 VHF Antenna : An array of two Yagi AIS antennas
3. You need a cable and the relevant connectors to connect the antenna with the receiver. The best choice for this cable is the RG-213 type. If the distance is shorter than 5 meters you may also use the cheaper RG-58 type. In any case, the length of the antenna cable must be kept as short as possible. You will also need a serial cable (a common RS-232 serial connection cable) to connect the AIS receiver with the computer. We have successfully tested a 15-meter serial cable, so we were able to place the receiver very close to the antenna, while the PC was 2 floors lower.
4. You need a software
You need to download for free a simple software for processing and uploading data to the central database. It is a windows-based service program that runs on the background or in the foreground if you wish to keep an eye on it. It requires the existence of the Microsoft .NET 2.0 framework (if you do not have it already, you will be prompted to download it during the software installation).
Download the "AIS Logger" Software (zip file, about 0.3 MB)
Installation Notes:Run the installation package AisServiceSetup.msi and follow the steps until the end. The software requires the Microsoft .NET framework, which will be downloaded during the installation if you do not already have it.
A windows service will be installed (named AIS Logger). Locate the service in (Right click) My Computer --> Manage --> Services. Configure the service to start Automatically and start the service. If you wish to see the AIS data collected and processed, check the option 'Allow service to interact with the desktop' at the 'Log on' tab, before starting the service (if you do so, please note that the program will stop when you log-off from windows).
That’s all! Start seeing vessels in your area! Ask us to put in our our site a direct link to your area.
Can I avoid using a computer?
Yes! and this is the simplest and most robust solution, since you will not have to keep a PC and a software running. You will be also able to place the receiver very close to the antenna, even if the network port is 100 meters away. In order to process and send us your collected data without using a computer, you may use a receiver with an 'Ethernet' interface, which connects directly to the network (see the receiver COMAR SLR200#925; (~550 €). Alternatively, if your receiver has a serial port, then you may use a serial-to-ethernet converter that collects the data from the serial port of the AIS receiver and sends them directly to our server. In both cases, it is not necessary to use a computer and the "AIS Logger" software to send the collected data to the central server.
We have successfully tested the 'Digi One SP' Serial to Ethernet Converter (~ 150 €)
and the 'Netcom 10S' RS-232 to Ethernet Converter (~ 70 €)
The converter must be configured to send the data directly to the address '195.251.168.18', UDP port 5321. Please contact us if you need further support on this.
http://www.marinetraffic.com/ais/addyourarea.aspx?level1=150
