I have been using Wally World marine gear lube for years or West Marine oil when it's on sale. Don't use automotive oil. Marine oil has additives to keep water in suspension. That's why it turns milky when water leaks in. With automotive oil water that may leak in stays separate. If enough water gets in the lower gears are running in water.
