AM/FM antenna
bayracerL.I.
I need to replace my antenna it was pulled out by accident without me checking where it went. Its a motorolla connection to strand wire. Where do I connect the strand end to ? Nothing? rout to isolated metal?
Your description confuses me, however, here is a generic answer:
The wire between the antenna and the radio is coax. There is a center conductor ( wire "a" ), surrounded by either an air gap or plastic insulator. This is wrapped in another conductor( wire "b" ), which may be any combination of foil, loose strands or braid, and then the whole mess is wrapped in an insulator.
The center conductor ( wire "a" ) is the signal wire. The outer conductor ( wire "b") is the "shield" or ground wire. As you may suspect the shield is connected to ground ( somewhere ) and the signal wire goes from the antenna element and also to the center pin of the connector at the radio end.
Whew. Long way around... I hope that resolves the issue.
the stranded wire goes to the center connection of the motorola connector--probably put a bit of solder on the wire, and then heat the tip and sweat the wire into the plug of the motorola connector. Actually this may not be a coax, just a single "long wire".
A Motorola connector is a coax connector. There should be two leads, a center and a shield. It is typical for the radio cabinet to be grounded, and the outer contact of the Motorola connector ( female) is connected to the cabinet. The center conductor, usually -not- stranded, is the signal. Obviously, there are variations in the wire type, but the connector is a "standard".
( Image from Tower Electronics )
Often, on a boat, there is no coax and no shield. Just the Motorola plug with about four feet of stranded wire soldered to the center connector. The wire is to be draped behind the radio or fastened to the structure of the boat with tape or such. The wire is supposed to act as the antenna. This works in strong signal areas but if the wire is mounted horizontally, it's pretty directional. A bad thing on a boat that moves and turns.
If you want good reception on a boat, your best bet is to install a "real" AM/FM antenna. An external, vertical one.
I have heard of folks attaching the antenna wore to a bolt holding the bow rail. Worked great.
Originally posted by KiDa
I have heard of folks attaching the antenna wire to a bolt holding the bow rail. Worked great.
This will turn the rail into an antenna if the rail is not gounded somewhere. It may work better than just a wire, but not as good as an actual external AM/FFM antenna.
No Argument here. I do not have trouble drilling holes in my boat. I have trouble drilling holes correctly!
Well I am running out of places to mount antennas. I use an XM/SIRIUS splitter so I could mount my AIS stand alone GPS up slightly below the anchor light above the radar. This weekend I needed to add a pair of low mounted fiberglass antennas one for AIS a 4.5dbi 4' Digital VHF antenna and the other a 4' Digital for my KVH TracNet100 cellular based unit. I got a pair of swivel adjustable rail mounts with a large hex head bolt and put them on each side of the boats angled vertical grab rails. They don't look everywhere and have some blockage but they work. As far as the AM/FM I have a unit made by Shakespeare that the wire is vertical behind the side windows where they are blocked from view by the inner fiberglass wall. I works great on FM but AM is so-so. So to really listen to AM I use my Kenwood TS7000 ham rig and tuner on my 23' Digital SSB antenna it works great. The ham rig has a general all mode coverage receiver. Now I will be replacing my old Garmin XM weather receiver with a SIRIUS all in the antenna unit NEMA2000 device with the audio lead adapter so I will no longer need the XM splitter and SIRIUS module on my Jensen entertainment radio. I'm done until the FB150 KVH comes out then I will be swapping out my TracPhone 252. I used through fiberglass fixtures that seal the antenna cable with a grommet and a nut to tighten the seal down along with 4200 on the cable. The fixture a round stainless disk is help in place with 5200 and 3 #6 screws (pre-drill). I found out the center where the coaxial cable goes into the boat needed to be drilled out to accept RG-8X with the female mini PL that digital puts on the end of all their cables.
I don't have a clue as to what you just said. Is any of the stuff for sale?
I don't care if it works, as long as it looks cool!!!!!!!!!![:-banghead]
Seriously, I have some GPS / Loran antenna questions for you. I shall ask offline. What is up with the XM weather I keep hearing of?
