Anchor Alarm App.
There is a new app for the iPhone called "Anchor Alarm" that does just what it says.
Now you can have your iPhone by your bunk side running as an anchor alarm. Check it out. Pretty cool and useful.
I forgot to mention, the little blue book, "Boater's Pocket Reference" is now available as an app as well. Very nice to have.
Might be a good idea... usually the GPS is too far away.
good to know. I use a portable Garmin which i set by my bed every night when on the hook. I sleep much better that way.
I set the alarm depending on the conditions and whether i want to be alerted to wind or current shifts.
the best thing about it is being able to take a quick look at the screen and knowing what's going on, even if you just wake up without the anchor alarm ringing. If you have to get up to take a look outside or look at the helm GPS, it's much harder to go back to sleep.
I had 20/25kts here in titusville last night but slept well knowing that if the anchor dragged, i'd wake up.
does anyone know if the Iphone is actually recieving a GPS signal or just trianglating the cell phone towers? I'm going to assume that the GPS position is way way more accurate on location vs the cell tower trianglation. sounds like a great app, but i would like to know exactly how accurate it is before counting on it. of course having the phone alarm on is still better than nothing at all.
This was brought up in another forum but I never saw the answer to it: If I leave my I-phone on the boat with an anchor alarm set; can I have it call another phone if the alarm goes off? This would be handy when anchoring to dingy in to a resturant, etc. If the I-phone wouldn't do this does anyone know of another device that will?
The Gen 2 and 3 phones have GPS in them. It seems to be as accurate as most any hand held GPS from what I've seen using one.
My set up for anchor watch while sleeping at night is a 10" screen Garmin attached to the cabin ceiling just above my bunk that is in the V berth. The mounting bail has multiple 3M Marine Reclosable Attachment Systems on the bottom to attach to the ceiling. This makes it portable to be able to relocate it to the helm if needed. The antenna is attached to the side of the bail with a SS rectangular base for 1" tubing then a short piece of 1" tubing to a 90 degree 2 way elbow then another length of 1" tube that has a rail mount with a 1"-14 thread clamped to the tube. The antenna is then attached to the 1"-14 thread.
This then gives you an alarm and location of the anchor and boat while using the bread crum mode.
I'll stick with the GPS method. Trying to get away from Cell phones and computers except at work. Dont want any brain tumors...
If your iPhone is in your cabin with you, how is it getting the GPS signal?
Same way a hand held does. Through the air.
The phone does not need to be pressed against your ear in anchor watch mode. Just sitting on the night stand. :-)
I would think triangulating the cell phone towers is the way the GPS works on the iPhone. It seems to be as accurate as my Garmin in the car is. I have and older handheld GPS but it doesn’t work inside the boat. Would be well worth the 10 bucks if it just woke me up to check to see if the boat was moving so I could go up on the flybridge to check the main GPS. I would be able to hear the main anchor alarm as soon as I came outside onto the cockpit and would have a heads up as to what was happening.
If GPS is available the iPhone does not triangulate off the cell towers. Mine picks up GPS pretty well frominside the cabin. My iPhone seems to be accurate within about 10 to 15 feet. If you are moving at speed it doesn't update location as quickly as my chart plotter but at slow speeds seems to work well. I would guess it would work great with the anchor alarm as you would change position fairly slowly.
The only downside I see to this App is that the seller wants $10. That's a lot for an iphone app.
The newer iPhones have GPS receivers built in, as do many Blackberries and several others. I have a Furuno RD 30 mounted next to my bedside with a nice big display that can show all sorts of data in a variety of formats. I usually have it set to the anchor alarm feature and in some cases also the depth alarm as well; the ability to display and trigger depth information is a big advantage over plain GPS for me. It gets the data feed off my NavNet system via NMEA 0183; would work with any system with 0183 out. BoatFix sells it for about 300 bucks. Great little device.
I think the phone app is a great idea; one advantage of the RD30 is the screen is always on, you don't have to wake it up to get a quick lat/lon/depth reading. For those Iphone people who have it, doesn't the iNavX app include this function too?
George
If the GPS in the IPhone worked off triangulation of cell sites in this neck of the woods the GPS would be useless because AT&T cellular signals ARE NOT reliable. I know the GPS works for me in the remote areas of the San Juan Islands just fine with absolutly no cellular signal.
Just a thought.
Seems the iPhone uses a few ways to get the position.
In the iPhone's case, it means location is determined with a combo of GPS, Wi-Fi and cell towers, depending on what's available—and all that data is crunched by the "assistance server.
http://gizmodo.com/5015930/giz-explains-what-you-didnt-know-about-the-iphone-3gs-gps
Apple explains that the iPhone 3G and iPhone 3GS also use "wi-fi hotspots
and cellular towers to get the most accurate location fast" when GPS is not the most convenient method of location detection.
http://www.everyipod.com/iphone-faq...d-gps-how-gps-works-real-time-navigation.html
Capt, I just meant cellphone usage in general.
