Anchor brought me a present...
Hazzard
My heart is still pumping a little bit over this one. I had anchored out in a fairly good sized cove today (inland lake). I was about 20 feet from shore in about 15 feet of water. The boat was holding just fine after about 15 minutes, so I jumped in to swim.
I was in for about 15 minutes and the wind really picked up. I then noticed that I was about 10 feet from shore and heading sideways towards the shore (very rocky). I immediately swam to the boat and almost hurled the 13 year old on board. I got in, fired up the engine and pulled away from shore to about 20 feet again (anchor was still out). I then went to pull the anchor out and as I pulled it up, I noticed a HUGE piece of a tree stump attached. At this point, I had blown back even closer to shore. I had to tie off the anchor, so the anchor and stump are dangling a few feet off the front of the boat. It took all of the strength that I had to pull the tree stump up above the water line. It was a good two feet around. Then I run back and now I pull out about 50 yards from the shore.
It took me about 10 minutes to work that stump off of the anchor. I was laying on the front of the boat and nearly went over a few times. I came close to having to cut the anchor. I hate the anchor and will get a new one asap, but I didn't want to lose the chain rode.
Anyway, after that one I called it a day.
It now has me thinking, has this ever happened to anyone? What is the most interesting thing that you have drug up with your anchor?
Maybe you should have had a PFD on while working with that tree stump? Just a thought!
One time I was anchored in a river with strong current running. When I went to pull up the anchor I struggled and struggle. Cleated the line and used the engine over and over again. I didn't think the current was that swift!!! Finally the came lose---from a log which was so saturated, it couldn't float. No wonder........
Another time I came up with two anchors and some chain. My anchor had snagged another anchor which someone had cut free. I still have the anchor and chain on my bow. Someone else's loss was my gain.
Yep, I've pulled all sorts of stuff up with after anchoring down in the back of a cove, which we do every time out. Last week end after spending quite some time in a narrow but deep cove, we decided to go tubing. After getting the tube and riders out and rope ready, I had drifted very close to the bank. I turned as hard as possible and started to pull away when the engine stalled. After several attempts each time I put the boat in forward the engine would stall. I pulled up the outdrive to find a large diameter rope wrapped around my prop. After finally getting it unwrapped I started pulling up the rope. It had a pilon attached to the other end. Apparently it had been drifting in the main channel at some time, and some good somaritian towed it into the cove. Well they should have tied it to the shore instead of just letting it sink. It gave me a bit of a scare but it could definately had been a lot worse. If my prop had hit that pilon I would have been rowing home.
20 feet from shore and in 15 feet of water?--How much scope did you have out? Don't blame the anchor--it may be fine--what brand, size and type of anchor do you have? You need to have at least 3:1 scope--better to have 7 to one.
What have I brought up? A ships steering wheel from a wreck, a full Bimini top, a dirty diaper, a full sized Mason Jar, an octipus, a battleship chain (3" diameter links-in Rhodes [Greece]), all sorts of tree branches and large logs.
When you anchor, set out appropiate scope, feel with your hands how the anchor sets, then back down on the anchor under power, with range markers to be sure that you are not dragging.
Hi Hazzard, a friend of mine with a 330 Rinker snagged a huge stump with his anchor 3 or 4 years ago. When he went to weigh anchor with the windless he knew it was hooked to something but didn't know what. The windless moaned and groaned but do you know that it lifted up the stump, the rode was so entangled in the stump that he boated into the marina with the stump still dangleling from the bow, nosed it up to the dock and the dock hands unraveled everything. They couldn't believe the windless would have lifted it up, I don't think mine would. I have another story that I'll tell you about one day, happy boating.
Tfret... are you on SML? If so... thats where we are. The lake always has anchor "surprises". We've pulled up everything, including a 40' tree. Yeah... talk about sawing away! Thats what happens when you boat on a flooded mountain!
Yes, perhaps I should have had a PFD on but I wasn't thinking about it at the time. I was thinking about trying to save my outdrive and hull. I had at least 30 feet of scope out as I was only going to be there for a short time (2 hours or so). Now that I think about it, I was about 30 feet from shore. I think what happened was the anchor had snagged on the stump and held okay, then when the winds kicked up the force of the boat caused it to come loose from the bottom.
It is a Danforth anchor and I can't stand it. I'm going to get a Delta Fast Set in the next couple of weeks.
Good to see you Tom.
Yesterday my anchor brought up all sorts of weeds and crap(?) from the bottom of Zachs Bay. Come look like human waste... I don't know why anyone would swim in that.
[:-crazy]
I think the worst thing I ever pulled up was a commercial sized telephone cable. I was having all kinds of fits, didn't know if it was electric cable or what. I put it up and down a few times hoping that it would fall off the anchor without me having to touch it. Long story shortened <snip> it turns out it was only a piece about 10 feet long just sitting on the bottom.
Inkblue, from Manhattan, thinks Zachs Bay looks bad!
Probably just some oil residue and mud mixed with the sand. Lots of eelgrass and other seaweed in that area too.
Pulled up my own anchor that I had lost the previous year.
My stupid tricks with anchor story. Threw a serpentine belt (was a regular occurence) and anchored off the channel. Finished putting on a new belt and found I had drifted into the middle. Quickly started the engines and pulled up the anchor to find a piece of rope dangling into the water. Figured that was why the anchor drifted and wanting to get out of the way, I take off for home. Start hearing a banging sound from somewhere. Check the cabin, tool box, nothing rattling around. Pull off to the side and pull on the rope hanging off the anchor. Find an eight foot piece of rebar someone bent into a V to use as a temporary anchor. While I was cruising, that rebar was dragging under the boat and banging on the hull. Luckily only scuffed the antifouling and didn't chip the gelcoat. What are the odds of that?
Even more lucky it didn't snag a prop!!! But where was your anchor? Did you lose it?
Yup farming the bottom here can get you some real interesting stuff < grin >
The one that sticks in my head that took hours was some old booming cable. Boat was not going any were. Finaly managed to get the hook about two feet shy of the surface and cut the cable off it with bolt cutters. The cable had to be hundreds of feet long kinda bundled making for a great mooring weight. I was able to work the few strands the anchor caught loose enough over several hours.
I carry bolt cutters, axe, chain saw, hack saw etc. for such moments.
Dive ticket and gear would be a great option. I dont have.
15' of water plus... 4' to your bow ? anything less than 100' is not going to work except in dead calm conditions. not even worth trying... it's a receipe for disaster, all it take is sudden summer afternoon thunderstorm to send your boat ashore. I dont' think you should be blaming the anchor...
we dont' have stumps around here, the only thing i ever picked up was an anchor with 10' of chain. probably a 15 pounder. not in great shape but i still have it in the anchor locker...
Pulled up a cinder block 3 weeks ago, had to cut the anchor loose last weekend, I think I had Jimmy Hoffa hooked and he wasn't ready to come up...
I saw a houseboat using a cinder block as an anchor one time. That was a good laugh. Good thing the wind didn't come up!
I took my 3 y/o son and a friend's kid out fishing on Canandaigua Lake here in NY. I am a lousy fisherman, but I managed to hook a boarding ladder with my anchor. The thing had to be 5ft tall, the kids got a kick out of it.
