Anchor Chain Questions
Sandy K.
I've got a 37 Egg Harbor Sportfish that we use to fish offshore. I've decided I want the capability to anchor in deep water - up to 600' deep. I've purchased 2 spools of 1,200' each of 1/2 3-strand line, which I'll be splicing together. I'd like to have 40 feet of chain between the line and the anchor. I'll be buying a Danforth anchor. From others at the docks, the 1/2 3-strand is more than sufficient to hold well, even in rough seas. The key is having 40' of chain to keep the anchor angled correctly on the bottom.
My question is about the chain - what size links should I be getting? Boat weighs in at around 30,000 lbs. Is it necessary to get stainless?
FYI - we won't be using this system in the windlass. Plan is to retrieve anchor using an anchor ball system. This will not be the primary anchor - it will be kept in a large bucket and used only when we venture far offshore - 20 - 100 miles out. We plan to deploy from the cockpit and secure at the bow. Retrieval will also be done from the cockpit.
TIA,
I would use 3/8" HT galvanized chain since you would probably have to haul it up by hand.
Agree with the 3/8 HT. Stainless is not necessary.
JohnC does a lot of offshore so he can chime in with some experience.
Is there a windlass involved? If so, you HAVE to use the chain that the windlass was designed for. Otherwise, use whatever you wish, the chain will be stronger than the rope.
He posted that he won't be using the windlass.
Certainly, stainless steel is not necessary.
As for 40' of 3/8 HT chain, I hope he's taking Hulk Hogan along as a guest. That, plus the anchor will be quite a load.
5/16 should be as strong or stronger than 1/2" line.
That's what I was thinking too... 40' of chain and a 40# or so anchor is going to be a lot of weight to lift several hundred feet off the bottom. I think a windlass is in order, and a good one at that. So pick one out and get the chain to fit it... even if you don't buy it now you probably will (and soon), and it would be nice to not have to replace 2000'+ of rode and chain.
Folks, read the post more carefully, he isn't hauling it up by hand, the boat will be doing via an anchor ball. That's still a lot of line to coil up, but nobody is going to be lifting it off the bottom.
What would be ideal is a combination windless/Capstan Winch so you could raise your main using the windless and your fishing anchor with the capstan. It may be an expensive refit but your back will thank you.
If your planning to have a deck hand do the lifting disreguard the previous advice:-)
Thanks for all the replies. I'm not anxious to replace the existing windlass until I know that we'll be making regular use of the capstan - too many other expensive projects this year. Have already purchased the 1/2" line, so we're sticking with it. At this point I need to purchase the chain and anchor.
Fortunately, I'll be up on the fly-bridge and my "crew" will be handling the line retrieve. I guess if I get too much complaining I'll have to consider a new windlass/capstan combo, but until then I'll let them haul in the line. After all, 2,400' of line is only about a 1/2 mile that they'll have to haul in :>)
I have used the anchor ball system for years with great results.
Really saves your back.
My only concern is with the weight of chain + anchor.
Make sure you use a float that can handle that weight.
Using it to chum Tuna?
Capt Tom
I'm curious as to where you are going to stow 1/2 mile of line and how much is that going to weigh wet?
Usually in plastic drums in the cockpit. As for the second part of the question - a lot.
Yup, plan to keep it all in one of those blue plastic drums found lying around the marina. Plan is to not keep it on the boat unless we're heading offshore. I expect it to be quite heavy - will need to use a hand truck to move it around.
Expect to use it for both chumming tuna at the canyons or anchoring over some structure and bait to try to jig up some bluefin a bit closer in.
I about shat when I snagged my anchor in 100ft of water knowing I am no longer in good enough shape to get to that depth to unsnag it and replacing all that chain was going to be a very large pain in the wallet. I was happy as hell to finally feel the anchor break free and it did not bother me one bit to see it come into the pulpit bent in half. I can't imagine what all the gear your dunking is worth!
Unfortunately, it's all part of the cost of going offshore to find the big ones.....
I figure the whole setup is going to run around $800.
Why don't you set the anchor up to break away. That way if you get hung up you won't lose it.
