It depends on the depth of the water plus the distance from the surface to the windlass. You should read up on anchor scope prior to purchasing. Also, it is recommended that a boat of your size have a windlass which accepts chain and line. Use chain which is at least the length of your boat. Again, you need to study and understand anchoring prior to your purchase.
Good luck.
