Anchor swivel joint
JOSEL
Some days ago my anchor swivel joint broke, I was lucky it happened at daytime and I was on the boat. I know the joint is usefull when you retreive your anchor but is it really necessary? Ideas? Probably I will buy a new stronger one, recomendations? I have a Delta anchor, a REGAL 3880.
Jose
I got one of these. Says German made, looks like it was a side job from a Swiss watch maker. It is a thing of beauty and never has let me down.
http://www.boatfix.com/shop3/store/viewItem.asp?idProduct=15345
Suggest you google Kong anchor swivels.
I looked at several different brands of stainless swivels and this was by far the best out of the bunch. I've had mine for three years and it's worked flawlessly.
Many thousands of nights at anchor never with a swivel (OK I owned one for awhile, but I realized it often didn't work well, and was a weak point in the system). Not necessary.
Josel- Swivels certainly can be a help , particualarly if 3 strand is involved. However, swivels are a very common weak link if not sized correctly. When you set up the rode, were you very careful to at least match the load capacity of the swivel to the chain, NOT match physical chain diam. size? I.e., most 3/8" swivels are much weaker than 3/8" chain , so a larger fractional inch swivel must be used to match, or better yet, exceed load capacity of the rest. GeeBees swivel type has a good reputation and great slim design.
I have a 55# Delta with a 5/16 chain rode on my 40' Silverton. The first time I used the anchor I was impressed. Darn near got a whip lash when it set. But troubles soon followed.
Later that year I could not get the anchor to set no matter how I tried until I installed a swivel. My problme was noticed when the windlass retrieved the anchor and the chain was all twisted. Maybe if I was using a chain/three strand combo for rode I would have been OK. The swivel I used was an old one I modified years ago. It is a large heavy 1/2" unit with a shackle like pin held in place with a cotter pin. Other than that flaw, this thing would never fail. So I took the unit to a welder and had the removeable pin welded in place. It is connected to the rode/anchor with shackles.
My 3-strand rode used to get all kinked up and then couldn't feed through the anchor wench. So I added a swivel and haven't had a kink ever since. Still works like a charm 10+ years later. I wouldn't be without it.
I had one like shown in GeeBee's picture. One day, believe it or not, the bolt that holds it together apparently came loose. I was able to retrieve the anchor with my retrieval line. Bought a new swivel and this time used Loctite on the bolt. Hope that fixes that problem.
I have the same as Gee BEe and Roy.
Used Locktite the first time, never had any problems or issues whatsoever.
Another vote for the "GeeBee" version.
Had a small issue with it on the FX-16 Fortress. It would ride up the opening in the shaft and get "stuck at a 45' angle because the throat of the swivel wasn't long enough. I just had to be exra careful when launching to be sure they were straight and maintain tension when lowering the hook.
My cruising buddy and I tried the nice looking swivels pictured above, and Kong as well, sized as big as could fit through the chain links and hole in the anchor, until they both showed some bending in use.
I didn't notice this mentioned in the thread, but attaching the swivel directly to the anchor can result in a side load against the swivel. Seems like a safer arrangement might be to connect swivel to anchor with a shackle, so the swivel can always point toward the pull of the rode rather than have the rode pull on it at an angle.
We decided to eliminate the swivel, a potential fail point. In our experience, with or without the swivel, the anchor would come up onto the bow roller the wrong way close to 50% of the time.
I use the Acco anchor rode swivel #4406-40011. It has a 3900 lb SWL (safe working load). It is good for 5/16" high tensile and 3/8" BBB chain.
If you want to make a screw shackel pin ALMOST permanant take a center punch and put a ding in the threads about half way. it will provide a mechanical interference, which will prevent it from unscrewing, but you can still remove it if you have to.
I never use a swivel and those links for joining chain because i don’t trust them as it is difficult of impossible to inspect them for wear and rust.
A trick to maintain good anchoring is to drop the anchor in very deep water then raise it slightly off the bottom and allow it to untwist itself. This works very well to untwist three strand that was improperly installed.
I repaced my 300 feet of rode last year and installed it by backing the boat until, all of the rode unreeled, without the anchor attached. Then attached to winch and reeled it in. Not a knot in the rode and the rode coiled perfectly in the locker
What GeeBee has only a really large one, no problems in the last 3 years.
