Anchoring etiquette
The same breach of anchoring etiquette happens to me once in a while. There is one anchorage that I use that lies between two marshy tule berms. Boats will anchor nosed up along the lee shore by anchoring in the muddy bank (or tying up to the bank) with an additional stern anchor.
Between the tules there is no set procedure. This is where I always hang out because I prefer to stay away from the skeeters near the tules and I just like swinging on a main anchor if I have the choice.
Usually, the first people at the anchorage will drop a main anchor and swing. After a while enough boats are swinging to use up all the swinging room. The new arrivals aren't going to turn around and go somewhere else. They wedge between the swinging boats and trouble can start.
So, I'll set a main anchor and swing because I usually amoung the first to get there and have the room. If anchorage gets crowded (and it sometimes does on weekends) I'll get into the dinghy and row out a stern anchor and marker to reduce swing.
Yes, you always run into the idiots on the 50-footers who think they have the god-given right right to anchor right on top of a smaller boat. Sometimes all you can do is leave, preferrably with the stereo cranked to the max and playing AC/DC's greatest hits at 3:00 a.m.
+ for local custom, otherwise swing away. That said...these discussions always seem to degenerate because I in fact don't think that a simple one sized fits all rule really works most of the time. To every "rule" there is a list of exceptions.
First, for a day anchor I think you had a LOT of rode out in terms of scope ratio. But then, you were in such shallow water that 30 foot of rode is not much at all, I mean its less than a boat length of swing. Since my boat is larger and a bigger sail, I often put out little more scope than smaller boats around me, but I really try to watch it. If the weather comes up I'll let out more, or set with more scope and then pull in to something a lot less.
In areas where space is tight, I don't care if you do show up early. If you are taking up the space that 3 boats would otherwise occupy, put out the stern anchor. Pascal, in the Northwest putting out stern anchors in boats our size is common. Most even have special rigs to make putting out/retrieving easier. You can always tell the full time cruisers, because they have the garden hose reel on the stern with the stern anchor line ready to go and these boats all START at 45 feet and go up from there.
Anyway, I guess it all boils down to local knowlege and also more local knowlege of the pro/con's of each of your choices is going to offer. Here are some strategies I employ: If I want to swing I go to the middle of the bay away from where others want to be. Yes, it seems that wherever you go, everyone else suddenly wants to be there. If you think weather may come up I anchor upstream from everyone else. Putting out more rode works great until the boats upstream of you who have not figured that out yet constantly break loose and try to come visit your bow roller. If you have someone with no clue and you don't want the situation to not fester until after midnight, go ahead and put MORE rode out right away. Swing a big arc and be ready to throw that extra fender between boats EARLY in the day so they can get clued in before you go to bed. Stern anchoring is great, but not if you expect a blow, always have an exit strategy. But, if stern anchoring is the norm, just showing up early and swinging won't earn you any friends. Get to the middle of the bay early where you CAN swing. In a close quarter anchorage where you are going to be swinging, tie a small line to a float or fender and attach it to your anchor so that it marks where you anchor is at. People have a harder time anchoring on top of you when they can actually see where your anchor is at, plus if they go ahead and try to anchor there anyway you can have drinks while watching them try to get your float line unwrapped from their prop.
I guess in the end you just have to anticipate and plan for the actions of those around you, while at the same time trying to be as good of a neighbor as you practially can. Anchoring is more about strategy than it is firm rules that everyone is aware of.
if you got there first, you have right of swing unless obviously the local customs are that everyone use a stern anchor...
about stern anchor, that works for a small boat but not for a larger vessel so saying that you should be courteous and use a stern anchor is not exactly accurate. Stern anchors are fine for small boat or when anchored for a few hours during the day. they can be downright dangerous if the weather goes down on you... and setting a stern anchor with a large boat is major PITA.
sorry, but if I'm anchored there first and a guy comes in too close, with a stern anchor, he's going to have to be the one moving away if doens't like it. all he'd have to do was release is stern anchor and swing out... if i can shorten my scope if conditions allow, i will but it's not up to me to move.
I only wish that was true!!! I have done considerable anchoring over the years, can share numerous horror stories. The idea that because you were there first.....and I have been entitles you to remain unobstructed is just plain wishful thinking. I do my utmost to avoid these situations by anchoring where others do not for fear of grounding.
Not only are there those who will give no consideration to who was there first but I have seen jerks put out 150' of anchor rode in less than 10 feet of water.
One has to just make the best of it, hope that your anchor neighbor is a nice, rational person.
Looks like coming to a consensus about anchoring etiquette is as likely as the possibility of a consensus on wake etiquette. Nothing wrong with a lively debate though. I had an annoying experience last week while anchored. After we set our anchor, a boat anchored directly in front of us, upwind, they left plenty of room for swing but after they dropped anchor 4 or 5 people on the boat lit up cigarettes. Nothing kills a beautiful sunny day with a fresh south west breeze than choking on someone else’s habit. We smiled and waved at them like we do to anyone that anchors nearby, then we moved.
Foggy, I know exactly whereof you speak. That's one reason I usually anchor well outside of where I could. Croton, mentioned above and where we have anchored out 4 times, is a perfect case in point. I like to have swinging room, so even when first there, we try to give ourselves as much chance to have it as possible. I thought that is what I had accomplished at Ocracoke... oh well.
If I come into an anchorage, and everybody nearby has a stern anchor or Bahamian Moor, than I am obliged to deploy in kind. As Pascal says, it is a RPITA on a boat like mine, but I can do it. Some places like many sloughs in the Delta and spots in the PNW, a stern line to shore or a stern anchor is advisable regardless of how many boats are there. Heck, in the PNW there are places with big rings anchored into rock walls to run your stern line to. That is one reason why it is important to study up as much as you can about the characteristics of where you are going.
George
Hatteras 56MY
And in areas with strong reversing tidal currents. A stern anchored into a 3 knot current is going to be trouble. Put simply, you want the "pointy end" facing into the current.
I don't go to the beach or sandbar hangouts, but at the "real anchorages" around here, stern anchors are not used. Swing with the rest of them.
Exactly, Ron. When you find yourself pointing to the west most of the day due to prevailing wind and you have significant current alternating between north and south then you don't want to be real tight on the stern anchor. In this situation I would have a stern anchor set in the middle of the average swing and leave enough slack in the line to allow for a little swing. That's what I mean by reduced swing. That keeps the boat from taking the force of the current broadside which puts a lot of extra pull on the anchors.
The places that I have seen stern anchors commonly used were always sheltered and out of major current but I always knew that if a strong wind came in from another direction bedlam would ensue.
Most boaters, as with life in general, don’t consider what if scenarios with anchoring and with today’s “I’m always right, you are wrong“ mentality being in a popular place isn’t as much fun any more.
In most anchorages around here (not necessarilly typical), the current is strong enough that wind only plays a part at or near slack tide. The boats swing with the current. It's important to note that powerboats may not react to current and wind the same as sailboats and keep that in mind.
Ron, in strong tidal situations, a bahamian mooring is the best option.
bottom line is... "when in rome, do as the romans". I think we can all agree on that.
this what's interesting about online forums, you get to hear about other people's experience on the other side of the country.
I've heard that, but never tried it. So far, I've been able to set my anchor well enough that it doesn't break loose. I also use my anchor drag alarm. And I usually try to anchor away from traffic and other boats.
Rob I have been boating on the Hudson for over 30 years and anchored in Croton countless times and I don't even own a stern anchor. I'm not saying that there is no reason for one but I don't spend nights on the hook and I don't raft up with large groups (maybe because I never been invited) but I rarely see stern anchors in use at Croton and when I pull up and drop I always leave swing room for everyone around me. If someone made me move due to their stupidity I would let then know that as I moved. I'm not saying get into a fight but simple saying that usually boaters make sure to leave enough swing to avoid accidents. This way maybe next time he will give it some thought. He otherwise may not even realize he did something wrong.
I'm also afraid to get too close to the shore maybe I would feel different if I got closer at least about the use of a stern anchor not the right for someone to invade my swing room. You did nothing wrong and it's a shame that you had to move.
I know scope varies considerably from the 7:1 "standard" based on all kinds of variables. At least there's a "standard" to begin from, though. Is there a similar standard for a stern anchor?
It is not as crowded in this "neighborhood", so you can generally avoid this issue, if desired.
But, in general, "anchor like the rest of the crowd". That is, if everyone swings on one anchor, so do you. If everyone sets fore/aft, then you should also. That way, you tend to resolve the collision issue when the wind/current changes.
That said, fore/aft anchoring is a very specialized configuration, and not suitable to many anchoring situations. It is, on occasion, necessary, but you cannot just set and forget. You must monitor the situation closely and re-set as required as the wind/current changes. Getting caught fore/aft anchored broadside to the waves is highly undesirable, and to be avoided.
re:scope
Scope is a factor in having the anchor stay set and re-setting properly when unattended. Too short a scope will tend to pull the anchor out of the bottom, and will cause difficulty when it needs to re-set. As a result, if you fore/aft anchor, and you intend for your aft anchor to remain set properly, you should use a proper scope: 7:1. Imho.
That said, a crowded anchorage can cause problems if using proper scope. The shorter the scope, the more likely the anchor will slip, and the more attention you need to focus on the issue. Because not all boaters are conscientious about "doing it right", there will often be an anchorage where one ( or many ) boats are too close to allow the use of anything near the required scope. For me, this means the anchorage is full, and I need to go elsewhere. YMMV.
Ad as for "the other guy", well, all I can say is that it is my job to exercise proper courtesy, and I appreciate it when others do so. Unfortunately, that does not always happen. I usually just leave rather than get into an argument if the new neighbor is a problem. The argument usually does not resolve the issue, and often destroys an otherwise nice day. I'd rather move and preserve my day, than attempt to match wits with an unarmed person.
When the wind or current changes you are now being held by the stern anchor. Therefore you should use the same "standard" applied to any other anchor on the boat.
In my case, my stern line is recycled bow anchor line. 100' of 5/8" line with 25' of chain connected to an FX-23 Fortress anchor.
Not respecting the rights of the person already at anchor is simply crude and rude behavior. There is no excuse no matter what the "local custom" may be.
Refering back to the OP, I feel the most concise answer is "Anchor as is the custom for the location", even if you are the first to arrive & legally may be entitiled to anchor in such as way as to restrict others from using the beach. By all means take the prime spot. The early bird gets the worm,& all that, but nobody has the right over others on public water.
Let's say you've never been to this location before. How do you know what is the "custom for this location"?
I say the first boat anchors as he/she feels is best and any following boats do the same or otherwise anchor so as not to interfere with the original boat.
Of course, not all boaters are smart enough to recognize how another boat is anchored or how it may swing. That's the problem the OP seems to have had.
I think the issue here was the OP's post that he was close to shore. I got the impression that they may have left the boat for some land activities.
For beaching a boat you should deploy a stern anchor
If you were just on a hook in an anchorage and want to single hook, move away from the shore and swing away.
OMG - I said on a normal weekend yes is warrants a stern anchor when its crowded. Last Sunday it was supposed to rain all day and there was about 5 boats in the anchorage. Meaning 100's of feet of shoreline for ANYONE else to anchor. Since the place was empty at 2:00 in the afternoon and no other boats near the shore at all I decided NOT to use a stern anchor. With the 30ft of anchor line out I doubt I was swinging more that 20 to 30 ft total since I was in the water with my 4 year old daughter that does not swim allot yet. When I left there was only 5 boats close to shore - 3 in the raft up that caused me to move and 2 other boats.
This is not the first time this has happened even in deeper water where another boat will anchor too close.
Here is another situation that has come up.
Say you anchored using your stern anchor. An hour later another boat drops their anchor/stern anchor right next to you not leaving enough for swing room if you pulled your stern anchor or did not have one out. Now all is fine and dandy. A few hours later you need to leave and the wind has changed and when you remove your stern anchor you WILL swing into the boat next to you. Now what do you do? According to some that is OK since it may "Be custom" but all in all respect other boater space and a little courtesy goes a long way as well..
Shorten up the bow scope while letting out more stern. (If only one capable person on board, let out some stern, winch up the bow, repeat as needed.)
Obviously you can only do this up to a point as you don't want the bow to pull free if scope is too short but it may reduce your potential swing enough to leave safely in the scenario you describe.
