Anchoring from the stern
BJL
I would like to consider a small cuddy cabin boat but would have a problem using an anchor on the bow due to a disability. Aside from using a windlass at the bow, is it ok to anchor only from the stern? Would make my life a lot easier and give me more options to choose from should we go that route.
Anchoring from the stern becomes problematic if the wind pipes up and the sea build up along with it. Your best bet is a windlass.
If caught in a sudden squall, while anchored from the stern, the boat could be swamped.
Even a large passing boat wake may cause water to come in over the stern.
not a good idea unless in very calm water with no chance of a wake. Many boats have been swamped that way, with tragic results.
A windlass is an option BUT you need to be able to get to it when (not if) it will jam.
how about a cuddy/express where you can reach the windlass/anchor line from the forward hatch. You can stand on the cabin floor, thru the hatch, and deal with the windlass when it jams.
On a small boat like you are considering it's possible to rig some blocks (pulleys if you like) so you can lead the anchor rode down the side of the boat. You're still anchoring from the bow, but you don't have to leave the (aft) cockpit. You can either stow the anchor on a bow roller or fish for it with a boathook.
The setup may not be the best but it's a lot less expensive than a windlass.
I agree with the others, anchoring from the stern is a bad practice unless you're in a place away from wind and currents. As others have posted, waves or wakes can enter the boat over the transom. Another problem is that the stern of the boat presents a large flat area to wind or current where the "pointed" bow does not. You have a much greater chance of slipping your anchor if you anchor from the stern.
If you're on a small lake you could probably get away with it. Not on rivers or areas with tidal currents.
i had a neighbor that had something rigged up like stmbtwle suggested. he kept all the line in the stern and the rode went up to the bow via pulleys and through the bow eyering. he had another line somehow tied to the anchor line, and when he had to pull anchor, he pulled the other line until it brought the anchor rode back to him.he then pulled the anchor back into the stern of the boat. it was a sailboat to boot. he couldnt walk, but had the whole thing rigged so he could sail solo.
Not to disagree with the caution expressed here, but I've anchored from the stern at the lake to eliminate the back and forth swaying that can occur when anchoring from the bow. Let me qualify this by saying that the boat was a 26 footer with plenty of freeboard.
My first boat was a 19' Bayliner cuddy with an OB. One time I had to use a stern only anchor in an emergency----well, a dumb mistake on my part----I ran out of fuel on the windiest section of a long reach of shallow water. Winds were 20-25 kts. I was within 30 ft of a rocky levee downwind.
As soon as the engine died from starvation, we threw out the stern anchor, amde sure we had a bit, the proceeded to put the spare fuel in the tank. My SO had to stand on the swim platform [200 lbs + weight of over 2 gals of fuel] to access the tank.
During this whole situation, we did not have one bit of water come into the cockpit or the bilge even when the swim platform would get buried in a wave.
So, it can be done, but only under the best of conditions would it be comfortable. I put in the stern anchor first, then go through the hatch to access the bow anchor and deploy that. Then I adjust the boat between the two anchors, and sit back and relax!
Good luck with your search for that perfect boat!
Don’t anchor by the stern but any manner of leading the line aft will work.
For a smaller boat even leading the anchor line aft through fairleads and having manual sailboat winch would work. Pull the anchor tight to the bow with the winch and cleat off at the stern. What ever works is what you need. Should be lots of used winches on the market. A self tailing one would be ideal.
The only time I'd have to do this would be in a protected cove where I fish alone and there are no wakes, strong currents, etc. Other times I have someone with me who can anchor from the bow so I think I can safely anchor at the stern when alone.
anything works, until it doesent. sounds like your mind is made up.
There's a way to anchor from the bow but deploy and retrieve from the stern.
You use an anchor ball and ring for retrieving and keep the anchor at the stern. You feed out and pull in excess rode much as willie suggested.
You need a line from the stern to the bow with a ring around the anchor line as a safety measure.
in addition to the risk of swamping, which may be limited on a boat with a closed stern, plan on using an anchor twice as big because of the shape of you stern and increased resistance to current, wakes and windage
instead of fooling around with pulleys and gimmicks, get a boat with a good windlass that you can reach from the forward hatch.
Charlie you took the words right outta my head. I never got the chance to say them.
Use a tag line to the bouy, keep it tied off on the side of the boat just out of the way, but the ring is still holding the Anchor line.
Keep the Anchor in the stern with you. Tie the Anchor off at the bow eye, or, run the Anchor line through the bow eye, so you can control how much line is out.
Using that big bouy to retrieve the Anchor it the easiest way, but if your Anchored in traffic, you may wish you had that windlass.
BJL,
What is your handicap? How capable are you of hoisting the rode by hand? Can you reach out over the stern to prevent the anchor from striking the swimstep/transom on the way up?
There have been a couple times when my anchor fouled on a log which required extreme effort to retrieve and clear. If you are not capable of hauling and clearing your anchor alone, I'd recommend limiting yourself to docks and slips if boating alone. Not everything done on boats can be safely done with a handicap. Know your limits for your own safety and that of your passengers.
Ingenuity can overcome almost any handicap. Heck, a swim platform can be used to hold the anchor if you can't lift it over the gunnel. Just tie it off.
A Davit and windlass combination would be helpful there. Swing the Davit arm over board and lift till the Anchor is up...
If you lodge an Anchor in the rocks, it can be a weight lifting contest. I've been out with a guy without legs, and when I needed help, he couldn't help very much.
It may not be a good place for a handicap.
My handicap is a prosthetic leg which only becomes a problem in certain situations where steady feet and balance are a problem. I've been doing the boating alone for the past 5 years but always in boats where I can run to the bow such as walk arounds or center consoles. Standing on a bow deck and pulling up an anchor is a little wobbly for me so I thought standing on the deck in the stern would work better where I have more balance. Might just have to stick to walk arounds :)
