Anchoring question
drfeno
I just came back from an overnight cruise to Sag Harbor NY, and I anchored in the cove under the fixed bridge. There were 7 or 8 other boats anchored, and a couple of them had their anchor lines going at a very steep angle down into the water. They also looked like another line was attached to the line and also going into the water. The steepness of the line makes me think they are not using the typical anchor, using 6-8 scope on the line, this was more like a 2 scope if that. is anyone familiar with this type of anchoring?
They may have an all chain rode with a snubber line attached. I expect the scope was probably more like 5:1 but with the chain weight helping it lay on the bottom it is decieving and appears more steep. You can read some additonal info on anchoring and snubber lines at the following sites:
<http://www.sailnet.com/forums/seamanship-articles/33209-have-hold-anchoring.html>
<http://www.bosunsupplies.com/Snubber.cfm>
Hope it is helpful.
Joe
you dont'say how the winds were... with all chain and little wind, the weight of the chain will often hold the boat with the chain going down almost vertically. the other line was a snubber to absorb the shocks on the chain in gusts
They may well have been using a kellet. Google for kellet and you will find penty of information.
A kellet is a weight that can slide down the main anchor rode controlled by a separate line that then causes the main rode to lay closer to the bottom and hence exert a more horozontal pull on the anchor. In tight situations or high wind conditions this makes a lower ratio scope as effective as a larger one.
