Another "Great Service" Moment.
AustinPaul
My boat came with a Davis Rudder position indicator. It's a simple little thing that mounts to your wheel's hub. It is so simple: one moving part. Principal: Gravity. And it's cheap-- less than $30! Obviously, we know how helpful it can be to know when your outdrive(s) or rudder(s) are straight.
Anyway, enough of trying to sell it! It has a rubber adhesive donut pad for mounting. Mine must have dry rotted. I checked the website, and the pad is discontinued. So he simply says "tell ya what, this one's easy. I'm just gonna send ya a whole new product". Sure, it's not an expensive product, but it's still excellent service all the same. I'm sure I could have used some double-sided tape to re-apply it, but all the same, it was a nice gesture.
I like to reinforce this great service, so if BoatFix sells them, grab one. You'll be happy with how simple and handy these things are. If they don't have them, Davis sells them direct.
Paul
I'd like to understand how this works...... if i'm not mistaken, the wheel can turn more than once....
GReat service, but I think it was the worst product I ever bought for my boat. I gave it away. I put a "real" rudder indicator on my current boat.
I didn't use it for the first month or so when I got the boat, but then I took to time to use it-- and it's always been perfect for both leaving the slip and for pulling away from someone after we've been rafted up. I wonder why it didn't work for you? It has been flawless in my application.
Paul
The indicator, which always remains at 12:00 and it lined-up with a fat while line when you are straight; it's weighted. When you turn the wheel, let's say 360 degrees, the fat white line has moved off center to indicate how far from straigt ahead the drive/rudder is.
Does that make sense? What you are talking about, is more akin to folks who put a ring of tape around their wheels at 12:00. You could be 360 off and not realize it.
It's a very simple gadget, I didn't pay anything for it, and it works perfectly in my application.
Paul
According to their website, it only swings 30° with each 360° turn of the wheel, so if you turn the wheel around to the right 3 times, it's only pointing 90° to the right.
Is the indicator accurate enough so you could decipher a quarter or half turn from center?
I put 2" of whipping at TDC on my wheel. If I've turned it more than once I know because I'm not going straight anymore.
I can see where this device would be very helpful, especially when my wife is driving and I'm skiing. She never seems to have the drive straight when she hits it to pull me up! When I gently explain that it's much easier to get me out of the hole when the boat pulls straight, she says something like, "Well, the wheel LOOKED straight up and down!".
AustinPaul, So you know- I get it. Mine, (brand unknown) is also a helpful tool at times. Especially when I am ready to back into a berth or for use in close quarter docking / manuvering. I like to know where the rudders are.
Yes, I have found mine to be so.
The most helpful part for me is when I am leaving the slip. I breeze straight out. I never know where I've left the drive when backing in on a windy day, etc.
