Another Sea Drive question
SSKdp06
The sea drive on my 1990 sportcraft has as you may have guessed it...a problem. The power trim will lift the motor, but once I stop raising it, the motor slowly lowers back to the bottom position. I posted a while back about this but now I'm more in a situation where I may be able to do something about it. The boat is in a yard locally and has been since I dropped it off to be looked at (a long time ago). The guy says that I have 2 choices...one being to find another used sea drive and replace the whole thing...or to take it all off and throw on a new motor and bracket(new meaning from his showroom). I have heard however that the problem I'm having can be fixed rather simply?...I'm also wondering if also buying a used motor and a used bracket and swapping out what I have on there now would be more economical. I'm also likely paying some nice storage fees.
ALSO*..I passed by the yard the other day...and I noticed that my boat no longer had the motor that I had bought the boat with on it...the guy swapped it with another motor without asking/telling me. Any ideas what this is about?
That is the very first thing you need to find our about...let us know
Perhaps in the company of a police officer... I think you need the law right now more than a mechanic.
SeaDrive is and isn't outboard. Powerhead and gearcase, yes. Bracket assembly, no. The tilt/trim mechanism should be very similar, but I don't know if an exact match. There's detailed troubleshooting in the OMC manuals that'll pinpoint what the problem is based on the symptoms. A couple special tools are needed to dismantle certain areas of it. There are lots of used OB transom/swivel bracket assemblies avaialable but probably not many complete SD assemblies. I think a good tech could part a good OB T/T assembly out and use it to salvage an SD T/T setup.
Yea I know that...It's I believe a 1990 Evnirude 225 on there (the motor he put on is a similar year 200 Johnson)...The guy also said it needed a carb rebuild...and said itd be around 800 smacks in the face(for the evinrude). I wouldnt know if that sounds right but I bet I could do it myself with the little bit of experience with 2-strokes i have and my omc manual coming in the mail shortly...But what legal action is there to be taken? Anyone know what should be done first and or how it should be done?
Just a thought, but no legal action would be necessary if you think a deal might be acceptable to you and him, he gives you a warranty on your new engine and doesn't charge you storage. Talk to him about it. Get the deal in writing and have fun this boating season....Life’s too short......I believe in picking my fights
