Another Transducer Question
gcolton
Well-known member
I am in the consideration stage of wanting up upgrade my boats electronice. At this time my top choice for new electronics is a Garmin unit.
It has been suggested to me by an acquaintenance that it is sometimes possible to not have to change transducers. Has anybody here done an electronics change and used the transducer from a different brand? This would sure save a lot of time, effort and cost if it did work. May even be the swing vote on whether or not I do the change.
Don't know if it would matter, but the boat is a 1999 Pursuit 3000. The existing electronics are Raymarine.
George
Best thing to do is get the make (probably made by Airmar) and model number of your transducer and call the manufacturer of the unit you want to buy. They should be able to tell you if it is compatible or not.
yes I did exactly that. Replaced the head unit and used the existing transducer. And they were different brands. Get the new head unit, tag a 12V supply to it, plug it in and see if it works.
How many years apart were they in manufacturer? The old electronics on the boat are 1999 models.
I talked to Pursuit this morning and they could not give me any information. They did not install the electronics in that era. Electronics were installed by the dealer. The Pursuit rep said that it is possible that the 1999 model was analog while the new models are digital and therefore would not be compatible.
So far I have not even been able to see the transducer on the boat. I think I will have the boat pulled so that I can see where it is located and then maybe I can find it from topside.
George
The head unit I replaced was a 93' So there was 16 years difference. And as it turned out the 93 unit probably wasn't defective, it just needed to be tweaked by tuning the sensitivy knob on the back. But since it was installed at the factory it would have involved hours of dash diassembly to reach it. I chose to remove it from the front (by destroying it) and the replacement 'snug fitted' in place. Now I can tweak it without any disassembly.
