Have an old 8 foot fiberglass antenna extension.
I want to cut it down and reuse the top male end piece. Has anyone ever done this and if so the best way to remove the fiberglass from inside the end piece?
FYI - Went better than expected. Cut to length needed, using a hacksaw. Used utility knife to scrape away most of the old antenna composite from inside male top piece. Sanded the cut end of extension and epoxied male piece back on.
