- Apr 26, 2007
- 26024
- 261
My 2001 328 Four Winns I purchased this spring had Interlux VC Performance Epoxy applied to its underside in 2006. The previous owner boated in the Trent Severn waterways here in Ontario, Canada were antifouling was not much of a problem.
However, where I boat (Lake St.Clair and the Great Lakes in Ontario, Canada) we need a decent antifouling paint on our boat bottoms.
I called Interlux and the good news is most antifouling paints are compatible with the Intelux Performance Epoxy - that's a good thing.
I knew when I bought this boat that I would give the underside a good scrubbing every three weeks or so to keep the bottom reasonably clean and I would then apply appropriate bottom paint next spring before launch.
I am considering applying Interlux Micron CSC or Interlux VC-17.
The Interlux technical help support claimed that at the same cruising speed (30 MPH) that there would be about a 500 RPM difference between CSC and VC-17. Meaning at a 30 MPH speed your engines with VC-17 would require 500 RPM less to obtain 30 MPH as compared to CSC. That to me is quite a significant difference over the course of running the boat for the season.
Does this claim sound reasonable to you? Would you have a preference between VC-17 or Micron CSC or is there another bottom paint that you would recommend for my boat being used in the fresh water Great Lakes area?
My typical cruise speed with the existing performance expoxy is about 28 MPH at 3300 RPM when the boat bottom is fairly clean.
Boat has twin 5.7's with volvo duo props.
Mike.
Mike.
