No question about it, I am an amateur, a weekend boater and part time mechanic for my own boat.
On winterizing, I have done over kill with a ‘better to be safe then sorry’ approach. When it comes to winterizing, I am not a minimalist.
#1) With the boat out of the water I remove the hose from sea strainer that goes between the strainer and the sea cock. With the sea-cock open I poor some pink -50 RV antifreeze down the hose so it runs out the sea-cock.
#2) I exercise the sea cock by closeing and opening it several times.
#3) I remove the cover on the strainer, remove the strainer filter and clean it via rinsing it with a garden hose and nozzle. Replace the filter and close the cover.
#4) I re-attach the hose to the strainer and remove the opposite end of the hose from the sea cock.
#5) I stick the hose in this first gallon of pink -50 RV antifreeze. It’s slightly less then full because I poured some out the sea-cock in step 1. I put 2 gallons thru the A/C unit that I suck in by having my wife turn the A/C on, suck the gallon container empty, then the wife turns the A/C off then repeat with another gallon.
#6) Re-attach the hose to the sea-cock.
#7) In the cabin I remove the air filter for the A/C unit and clean / rinse / replace.
#8) I dump RV antifreeze into the A/C unit’s drip pan so the antifreeze runs out the pan and down to the sealed bilge pump. I keep adding antifreeze until this pump comes on. This take about a ½ gallon. I do this step again with the shower drain. Yes, another ½ gallon. This means it takes me 3 gallons of RV antifreeze to winterize the AC unit.
I’m sure some people can winterize the A/C unit with less RV antifreeze. Its only $2/gallon so were only talking $6. Not enough $money to pay to replace one item if it freezes and ruptures.
