If your system has dexcool in it, you need to add dexcool anti-freeze. You cannot mix regular and dexcool together.
If you choose to remove the dexcool, because of the negative reports it has, make sure you completely flush the system and get all dexcool out of there. In fact, try to do it in the water where you can run the boat. Fill the cooling system with fresh water, and run the boat, flushing and running a couple of times to ensure all dexcool is gone. A wet/dry shop vac will work to remove antifreeze, just disconnect large hose, and vacuum out anti-freeze. than, add your 50-50 mix of whatever brand you desire. If your hot water tank is tied to your cooling system, be sure to flush that real good also. Good Luck.
