Any secrets to removing a windlass?
interj
I have the Lewmar Sprint 600 Vertical Windlass. I am trying to remove it to have it services. Removed the nuts on the 3 long bolts and cut away the cauking around the top. It wont budge.
I tried sticking a screw driver in through the chain inside the anchor locker and then pulling from the top, still not good.
I did not install this so I'm wondering if I missed something. Does the back plate get gluedon or something?
Thanks!
Try hammering the bolts up from the bottom, then go around the edge with a razor to cut all the silicon that is holding it.
It will take some "oomph" to get it free.
Thanks Hogan, i'll give a hammer a try, I guess I'm being too gentle for it. :)
I hope it's not set it 5200. Keep pressure on it. A buddy of mine set a bow pulpit on with 5200 and we had to move the boat so we had the pulpit over a dock, and jacked it with a hyd. floor jack, we had to leave the boat bow "hanging" on the jack all afternoon until it gave.
