any theories?
In the know
We all appreciate that as boaters we have to be ingenious at times given the confines we are required to work in. We often use tools to our advantage, beyond the scope that they are designed for.
Well today I may have seen the grand daddy of them all. There is 6 of us drinking and socializing as we all returned around the same tim. We see a just launched 80's vintage 40 plus foot center cockpit sailboat.
This guy walks down the dock carrying - a leaf blower. Yes a leaf blower. He gets onboard. We hear the leaf blower run, then the diesel fires and he is gone.
Okay any theories on why one would need a leaf blower on board?
He probably heard someone say "Run the blower before starting the engine" :}
Sounds about right.
Diesel guys the boat was diesel. Also you could tell by the way he rigged the lines to leave single handed and the way the boat was set up that he was no rookie.
"Diesel guys the boat was diesel"
I know ... that's why he had to bring his own blower!!!! :)
Maybe his battery was dead and he heard about a generator made from a leaf blower (from a guy heading to Block Island in a bow rider) so he got creative and charged his batteries.
Di he have an inflatable onboard? I use a shop vac with the hose switched to most inflate sponsons, then top off with a dual action pump or HPA source. Used a leaf blower last year because it was already out and the shop vac was in the back of the shed. Works awesome. Still need to top off, but it gets the bulk of the job done in seconds flat.
Only other thing I can think off would only apply in winter - and that is clearing snow off the boat (only works if it's really cold - doesn't do much for wet sticky snow, but that dry cold stuff, works like a champ).
There's a number of possible good Blow Boat jokes here......but I won't start 'em.
Auxillary wind machine? Illegal turbocharger when in irons?
There was an 8 HP engine secured on deck, but come to think of it, I did not see a tender on board.
The blower was used below decks. Literally, it started, ran about 30 seconds and then it shut off. Then he fired the diesel, and he was gone.
I am not poking fun at the guy, I am really curious what he had this thing on board for.
As noted, earlier, this guy was no amateur. The boat was set up very efficiently for sailing and he was methodical and prepared for the way he casted off.
The boat is flagged out of Annapolis and it was here to be painted, so I am guessing this guy has a long haul in front of him to get home.
He did it because now he's reading this and laughing at the stir he caused.
How much time passed between these two?
The boat may have been a little hot so:-
open the forehatch, leave the companionway open
Stand in the forecabin and start the leaf blower
Point the nozzle out the forehatch
let run for a minute.
Result - the cabin temperature is down to outside temperature.
When under way, the through draft coming in the forehatch will keep the boat at a reasonable temperature.
What lanbuilder sed, Plus, it likely moved all of the overly humid air out of the cabin. Maybe. I thimk.
That's plausible. Then again, he'd be topside until the boat was in open waters anyways - all those details to deal with in maneuvering a vessel from it's berth to open waters - that he'd be underway long enough for the aforementioned foredeck hatch to do the trick.
Or not. Just a thought. I'm curious now and trying to figure this one out, too.
