Originally posted by Robyns Nest
I wonder how that compares to a davit on the bow. My issue with dinks on platform is you have to remove the dink prior to backing into a slip or you won't be able to remove it after.
Well if the davit on the bow in on the same side your are tied up to.......you have an issue. Don't ask me how I know this. So tying up can be a hastle if you can't get the right side to tie up to.
Check with Rommer, his Hurley setup on his Regal is one of the easiest quickest dinghy setup I've ever seen. He can have his dink loaded and secured in 2-3 minutes. No kidding.
I would do that system first before a davit on your Regal.
