Anybody using a Bennett Auto Tab control?
Flattman
I just tried to order the a Bennett Auto Tab controller from Boatfix and found out the newest model (AC3000) won't be available until mid July due to engineering problems.
So does anyone have experience with the existing model (AC2000) and/or have you had any problems with it? I guess I'm wondering if the previous model wasn't broke, why is Bennett trying to fix it other than a cosmetic makeover?
In theory, this system seems like it would take the constant trim issues away which would be fine with me.
I had it on my previous boat and loved it.
I still have it on my 8yrs old boat and it still works as good as the day I installed it. Love it.
Had it on my Wellcraft and loved it!
I installed the auto tab controller AC2000 on my Larson Hampton 235 about 4 years ago. The problem i have is when i slow the boat down a little and then throttle back up they would over compensate and cause a severe list. The first time it happened it scared the heck out of us. I would have to manually take all trim out and start over. This hapenned on smoothe water. Bennett sent me a replacement controller and it helped some but every now and then it still happens. I have relocated the position sensor twice but no luck. I think the problem is that they react to changes too fast. One other point that may be a factor is the size of my tabs. I was told i need 18x12 for my boat which is 23' and has a dry weight of 4200 lbs. Every boat i have seen since in that size range has much smaller tabs.
I'm not knocking the system as for the most part it works very well especially when folks move around or back and forth to the cuddy. Plus i got tired of constantly adjusting the tabs and that in itself made it worth the expense. I would install them again.
I have had them on my Mariah for three years and love it. I have also had occasionaly the problem that Stevew reffered to. The other thing that I have found is that it is helpful to reset your zero position if it hasn't been reset for awhile. I don't know the engineering, but it appears to me to lose it setting after awhile.
I wouldn't have trim tabs without the controller. Also Bennett is the most responsive company I have ever dealt with. A real class act.
i'm thinking of adding trim tabs to my 16' boat and have heard nothing but the best of bennett. should i go with somebody else????
also, is hydraulic worth the $ or are springs ok on a fish/ski boat?
Wow, I guess the number of positive opinions speak for themselves.
SteveW, 18 x 12 tabs do sound a bit large for your boat but then again I don't think you can really "over tab" a boat. I'm sure they just make any adjustments much more sensitive and responsive.
I guess I'll go ahead and order the "older" model. My existing tab switches on the dash were factory installed and they just seem backwards to me and get me mixed up every time. I only have an 8'6" beam so the boat is pretty sensitive to changes in weight distribution and crosswinds.
Best investment I ever bought for the boat! All play now; no "fiddling" with the tabs!
I purchased the ATC from boatfix last fall and just got around to installing them a couple of weeks ago. Easy enough install for a DIY'r
if you're handy with basic wiring skills. The system works well, and I generally just set it and leave it alone. My only complaint is that the "on" LED is not very bright in the daylight, and I find myself trying to confirm that it is indeed on.
I had one, liked it. It was most suited ( for me ) for "river running". It was less useful when on on long runs through mixed chop ( it would get "confused" ) or while on autopilot ( the AP and tabs interacted ). But for around 50% of my operating it was excellent. One of the better "thingys" I bought for the boat.
Well, it looks like I'm going to have to wait for awhile to get one. Boatfix doesn't sell the old unit without the dual helm station and I certainly don't need that on a 26 footer.
I also checked some other sites and called a few suppliers to no avail. Even though some advertise it for a decent price, they can't get them anymore.
I figure I'm going to wait well past July when they're due to come out as I don't care to be a test bed for them.
Until then, I'll just continue to hear the ooh's, ahh's and get the surprised looks from those aboard when I accidentally pitch the boat over on its side with a misadjustment of the rocker switches I have now.
However, I was thinking that maybe I'll simply reverse the wiring on the switches so they work like my brain thinks they should. Push the top of the switch to "push" the bow down and push the bottom of the switch to "push" the bow up.
Maybe I'm just dyslexic.
