Attaching bimini
lil red truck
I'm about to drill holes into the boat to attach the straps for the new Overton bimini.
I'm mounting the midsection to the port and starboard rails with SS clamp-on jaw slides. Questions are:
1) Do I trust the hardware sent w/ the bimini or get new from the store? (I've had bad experiences with kit hardware)
2) What brand/type caulking is recommended?(the manufacturer doesn't mention any use of caulk or sealant in the instructions, but I'm assuming it would behoove me to use it)
3) If I need to back plate, how do I accomplish that?
if anyone has a good site for instruction please let me know. Thanks All.
#1.) I don't usually trust them to be high quality stainless. I always buy good hardware.
#2.) I use 5200 sealant on anything that could cause a leak into the boat.
#3.) It depends on the area where it is attached. Not having seen the boat that is difficult to tell. You will likely have to use your judgement there.
One thing to keep in mind:
If at all possible, fasten the strap mounts so that the pull puts a side load (shear) on the screws rather than trying to pull them out. IN shear mode the screws will be very strong and hold tight. In tensil (pullling) it is very likely that the screw will pull out of the deck.
If you have to fasten the mount in tensil mode then use through bolts and a backing plate.
Rod
5200 is a great sealant, but if you ever want to take off what you are sealing, you are in for a rough time. 4200 would be a better choice.
Thanks, keep em coming please.
abdiver, if I understand you-the less of angle the strap presents to the attachment the better. ?
1) I would get my own
2) 5200 is one step away from permamnent, 4200 should be fine for what you are doing
3) What are you drilling into? Is it a wood core?
"What are you drilling into? Is it a wood core?"
4)If it a wood core do I Not need a backing plate?
Sad to say, I don't know if it's a wood core or not (despite every Google trick in my book). I was going to put some painters tape on the drill bit and drill to 1/2 the depth of the screw. I guess when the bit comes out with or w/o wood, I'll know. Someone please stop me if this is the wrong way to proceed.
I assume you have drilled FG before, however I use a countersink bit for a turn or two first. This stops and cracking of FG from regular drill bit. Tape on FG also helps, and any problems will be handled by the 4200.
Thanks.
Assume that I know nothing. I was going to use tape on the surface and drill through it based on what I've read here before and some work with plexiglass.
When I drill into FG, along with the tape, I use a handy hand-cranking drill to get the drill hole started. then I switch to the electric drill to complete the job. I've never had any grazing of the gelcoat by doing it this way.
Good luck!
Thanks...besides the 19V, I have a 10.8 Skil that I was planning on using. Less torque, light-good for small jobs. I'm embarrassed that I don't know if the top deck and side are wood core. Can anyone help w/ this question?
If you can rig your straps to come off the supports at 90 degrees (which should give you about 45 degrees to the gunwale), you'll get good geometry for bimini support and screw strength.
I used the hardware from my kit and have had no problems after 7 years. 90% fresh water use, though.
I agree that 4200 should be more than enough. I was once told that if I NEVER want to remove it, use 5200. If I MAY want to remove it, use 4200.
Another trick I've heard of re drilling into FG is to start the drill in reverse first....less chance of chipping glass. I "always" use a countersink bit to stop chipping as well. I think what I use is called a rose bud bit ??
What Rod meant was if you can screw the eye pad that the strap hook onto horizontal say into the side of a cabin rathen then on top of the deack the pull on the screws will be better not pulling them straight up and more apt to come loose. if you go with screws id use #10 stainless with a 9/16" bit to pre drill the hole. of souse bevel the gelcoat with a screw ggun tip to prevent chiping.
