auto retractable trim tabs
greenstreak
How hard is it to make the trim tabs already installed auto retractable when ignition key turned off? What do I need to install for this to happen? I am afraid I will forget to raise them and when I load boat on trailer I will hit the bunk sticking out in the rear. The trim tabs are exacting inline of the 2 bunks sticking out.
art
If they are Bennets, all you need is their Auto Tab retractor. Simple to wire into the harness at the trim tab motor. Only costs a few bucks too. Then they will automatically retract everytime the ign. is turned off.
hey scorpio--thanks. I will check to see which brand they are. I have a Sea Ray boat and the tabs are original. I don't know which one they use.
Art
I'd imagine it would be easy to wire-in the retractor even if they were other mfgr like Boat Levelor, just cut off the connectors. Not a bad idea for cruisers but I decided not to add them due to frequently stopping to fish with engines off & not wanting to re-set trim. For me, even more convenient might be a 1 button push when desired for full retraction re-entering the harbor or just before backing into the slip, but it's still certainly simple enough to depress the 2 bottom tab-UP buttons for about 7-10 seconds until the pump sound changes. It is pretty important to get them retracted so they don't shovel in reverse or rams get fouled when slipped/moored.
http://www.boatfix.com/shop/scripts/prodView.asp?idproduct=25914
I have the Bennett auto tab retractor BECAUSE we stop to fish a lot. We probably run to 10 or 12 different spots in a day of fishing. Each time I'd have to remember to zero out the tabs to get ready for a run in a different direction after fishing a particular spot. Now I just have to adjust the tabs as needed once on plane. Great accessory!
And you could wire the retractor's sensor wire to a normally closed pushbutton switch to auto retract your tabs whenever you wanted to. The power source doesn't have to be the ignition switch.
This is correct.........
I did mine last season. I wired in the unit to the dash switch " aux " that also controls my GPS..... so they work together.
I have used the Bennett Auto Tab Retractor successfully on Boat Leveler tabs - wire away!
Sure would be nice to be able to click on that Boatfix link!
I know you guys all love the Bennetts on here, but I've got the Lenco electric tabs on my boat and with the trim indicator switch upgrade (led switch pad showing relative tab position) the control box is wired to a toggle switch on the helm. When you flip the switch to power down the tabs it automatically fully retracts the tabs before shutting down. When you turn the key off, it does the same (obviously since it kills power to the tabs as well).
Tim
Ok, I am going to play real dumb here.
Why do you need them to auto retract?
Many times when you get back to the dock you may forget to manually retract them. It may be weeks before you get back to the boat. In that time, little critters can attach and begin to grow on the extended tubes. Then when you do retract, it may bind and/or cause leaks.
Interesting. I always retract them when I go to dock becuase someone wants told me they can intefere with how the boat tracks when backing into a slip. Guess I don't need them
Dave......It just one less thing to remember to do......before spinning or backing down for me. When I enter my canal..... I hit one switch.....shuts down my GPS & retracts my tabs.....and Im ready to go.
Very useful for a trailerd boat. If you forget to retract the tabs after coming back in from a day on the water, and load the boat onto the trailer (especially bad if its a bunk triler) you could bend the tabs.
I put them on a Sundeck that was dry docked. Just another thing not to have to worry about. Pull in, shut down, tabs go up and I didn't have to worry about damage from the lift.
On the current boat, so far I've been able to remember to retract before backing into the slip. However I'm thinking that it would be cheap insurance for when I don't remember. And lord knows there are times/things I don't remember... Admiral's birthday was this week....
Bob!
