This adapter screwed into the shift cable end allows you to very easily insert the cable thru the bellow .
Accepts a solid control cable core to act as a guide
Also I`m redesigning the alpha remote res system that is NLA Machining a new style fitting that can accept a oil fill , barb for pressure testing or using a power trim hose from the pump and the gen ii res bottle and bracket. Using 2 1 x 4 inch flat brackets it can be mounted to the outboard side of either riser elbow or a convenient area inside the engine compartment. The gen ii bottle also allows a alarm circuit to be added
Approx fitting cost around 40-50 USD and customer supplies the reaming parts that are currently avail;able
Pics assailable this fall/winter
contact is btdoctur@gmail
