Long story short.. Pulled both motors and Got the bad tank out today, found small pin hole in bottom, washed bottom of tank to look at pitting couldnt see good so took pressure washer to it and while washing it found a total of 3 holes in bottom at that end.. Question is.. Tanks are 10 years old, 140 gal al. The marina called the original makers and got est of 3k each ( two tanks, sure both need replacing) could I have new bottoms welded on or should I bite the bullet and replace both with new?
