Hi all, I've been repairing my radar arch, covered in a another post. I now have Core Cell foam coreing in the arch
I'm installing a 4' open array radar. The radar unit will be mounted on a Seaview PowerTower mount. The holes are 7 inches on center apart.
I already drilled out the core material around where the bolts go and the cable. I widened the Bolts holes to 1 3/4 "and the cable hole to 2" then filled with thickened epoxy.
Now my question is do I need a backing plate for the radar mount? If so where do I go about getting one, or even someting I can drill out.
