basic electricity (battery drain)....
ed flanagan
my charger reads 3 or 4 amps just sitting at the dock plugged in to shore power(even after several hours sitting there, more than enough time to charge the batteries, which are new this year)....
if i take the positive leads of # one battery the gage reads zero amps..
seems to me if the boat is disconnected from shore power, both batteries disconnected, i should read an open to ground at both positive battery leads and the resistance between the leads should also be open. right?
also, how do you know if you have a battery isolator?
