My boat was surveyed this past weekend in preperation for the sale. One item that the surveyor picked up on was the lack of an acid tight battery box. Currently, my batteries (2 X 8-D and 2 X 4-D) are housed between the stringers in a housing made by the boat manufacturer. The housing is made of Starboard and has chocks to seperate and hold in place each battery. It is a pretty involved structure and its cover is not easily removed to check the batteries. This configuration is similar on all models of my particular make (Legacy).
Other than lack of ease to get to the batteries, the buyers surveyor did not like the fact that the starboard structure would hld the acid in should a battery fail. We all agreed that the likelyhood of a battery bursting was low, but idf it did happen, the problem would be more environmental (bilge pumps pumping acid over board) than an issue of acid eating into the fiberglass.
I currently have AGMs, which its my understanding, really do not require, or allow for any maintenance, am I correct?
Dan
Dan
