What a beast. That's great they've finally officially unveiled them .Sounds like it will still be a bit before they roll out the door to the wealthy public.
557 hp/6.162L/376c.i. production GM aluminum automobile V-8 MPI (returnless fuel system) engine with supercharger and intercooling/closed-loop cooling!/ dual mode, above and below exhaust sytem/ ZF electronically-controlled transmission in the mid section/even apparently available 6-blade Hering props up to 18"D. 1000 lbs. dry. This is a seriously broad stroke. ( 89 oct min. , 92 recommended for opt. performance. )
the engine is supercharged not turbo charged although i could see that as a future HP option. they will sell many of these to the goverment ,the navy ,the coasties, and the homeland/customs boys there pretty tired of swapping out blown up mercs on their triple and quad engine boats the big question is will it take a pounding?
