BIII stuck in reverse.
Shore
Spent the night out on the boat and woke to go home...she had another idea.Started the engine and the old girl started creeping backwards...lol.These don't start in gear so we all gave each other that ruh-roh look.
The stick was in neutral but the drive was not.I'm guessing a lower shift cable is in my near future.Throttle cable works right.
The odd part was I backed the boat into my spot and did several FtoR switches and it decided to just stay in rev overnight....2hr tow back to the ramp.
I did not stop it in gear..I don't think at least.
I have the drive off.I move the stick and the cable goes in and out of the outer transom assembly...I left it in forward to get a good feel of the cable and I can push the cable in and out...not real easy but with the stick in forward that cable should not move at all.
I'm thinking something that holds that cable in place inside has come undone.We did just put a motor in this thing.
Hmm..I need an extra set of hands.2nd time in two weeks I have pulled that drive off alone.
I know of the adjustment at the shifter bracket but the movement I'm talking about should not be there.I have the stick in forward which pushes the cable all the way back and holds it...I can push the cable back and out.It doesn't feel broken but as if the outer cover of the cable is moving around.
I found what seems to be the issue...the cable housing has seperated from the flange on the inside of the bellhousing.I tilted the bellhousing up and the cable housing just stays put.
This happened to me my while straightening out (w/single engine) right after exiting my slip. Before I knew it, my swim platform became a battering ram into the bow of another boat. Totally unexpected & after several anguishing seconds, I finally thought to kill the engine. Needless to say, both boats damaged. Reported to marina & insurance co. Then went home to wait for calls. Not a day I ever want to repeat.
Lesson hopefully learned, when struck in either reverse or forward KILL ENGINE IMMEDIATELY. Hope this helps someone else.
Mine was a bit more scary..we where in 2' water at the time and there was a person in the water behind me.
I knew something was up with the way it started up sluggishly.
It's a lesson learned for certain.
