Bilge alarm question
firepiper
Is there a way to put an alarm/buzzer on a pump that has an integral float switch? It's easy on a regular pump/switch.....new pump w/ integral float might have been a mistake. Thanks, Mark
It can be done, but it might be expensive and I know of no ready to use Common-Off-The-Shelf product. The best wat is to use separate pump and switch so that you can wire the alarm in parallel with the pump, but after the switch. Wiring the alarm in series would be a no-no.
Shouldn't be that difficult. Most pumps of that type have 3 wires, one for the float (always on) and one for "manual". In my experience any time the float comes on the "manual" lead becomes hot and can drive an alarm.
There's a trick to this though as any time you turn on the manual switch you'll also set off the alarm. You'll probably need to replace the switch with a double-throw switch, so the alarm only works in the "auto" position.
Offhand I can't remember how mine are wired but if you need it I can go down to the boat and figure it out.
Stmbtwle, I thought that would work too, (manual becoming hot....) So I wired it that way......not! After all that no good. It only comes on when I turn on the manual switch.
Hmmm it works for me, but if the manual lead doesn't become hot when the float kicks in then I can see why it wouldn't. It works for me, but the only auto pumps I have are the small Rules. My bigger pumps have a separate float switch. Here's a diagram if it's any help.Link
