Does anyone here have experience with the Aqualarm bilge pump counter/alarm switches. From their website they appear to be something you can just install at the helm using the wiring from the existing bilge pump switches. The one I am considering appear to only use the switch wiring (their item number 20043). I want something easy to install for piece of mind and would also like to have the counter to see how often the pump is running while I am not on board.
I do have a secondary float switch which is tied into my SeaKey system so it will notify me if there is a high water situation in the bilge. As such I don't want to wire in an additional float switch but would like the counter and alarm so I would know right away if the pump is running while I am underway.
This seems like an easy inexpensive safe guard.
Thanks for your input,
Kris
Kris
