I currently own a 2003 Maxum 2700 and my previous boat was a 2004 Sea Ray 220. Although they are very different boats, I have had fewer problems with the Maxum than I did with the Sea Ray.
When shopping around for my current cruiser I looked at Sea Rays, Bayliners, Maxums, and a bunch of others around 28 feet in the 2002 to 2004 ballpark. When looking at these boats, the all have the same power (Merc or Volvo) and they all have similar third party equipment ( e.g., pumps, A/C, tanks, etc.) so the big differences are design, manufacture, and materials.
The Sea Rays unquestionably had better parts, e.g., latches were stainless steel versus plastic, vinyl was slightly heavier gauage. But, the Sea Rays were desgined for midgets. SR designs just do not make very good use of space (or have enough space), particularly in the cabin. When comparing single engine cruisers around 28 feet, SR just doesn't compete when it comes to cabin space.
Bayliners often have very good layouts and space, but they use poor materials. Carpet, fabric, seat backing, tables, etc., were low quality. Design of things like windows is also poor -- those big side windows invariably leak at some point. Eevery Bayliner I saw had some evidence of water intrusion around windows.
The Maxums were a different creature. Especially in the 2001 to 2004 ranges, the Maxums have very good quality fabrics, vinyl, etc. (In 2004 they started using lower quality interior fabrics on some, which is when the switched the SCR to SE designation.) They were also very well designed. The earlier 2700 is somewhat unique in that it has a nearly 10 foot beam in a 28 foot boat with a single engine. (Around 2007 they went to an 8'6 beam.) It has much more space than a comparable Sea Ray, with the efficiency and lower cost of a single engine. Among other things, the Maxums are also well designed to avoid water intrusion issues, which seem to plague the Bayliner designs. While the Maxums apparently shared a bottom hull mold with some Bayliners, everything above that (including the port holes cut into the hull) was different. The big difference I saw between Maxum and Sea Ray (other than design): Maxums uses plastic latches, as opposed to SS on the SR.
