Boat Cover (Idea)
dinows
Every year I build a superstructure over my 30 Sea Ray, run shrink tape over the wood to the gunnels and hang a tarp and tie it on the bottom. Can anyone see anything adverse about building the structure over just the open aft area to protect the seats and just laying the tarp over the bow area of the boat without making the t-pee and let the snow accumulate. Cant see where it would hurt anything and would save a lot of work not building the second half of the structure. Boat is an Amberjack. What do you think ?
Thanks dino
Sounds like a good idea to me...this year I am doing just that, but I bought a pool cover to use (fairly inexpensive on the internet and they come in all sizes) and it even has the draw sting built in.
Can't be any easier or cheaper than that.
Do you think the tarp over the bow rail will hold up the the heaviest accumulation of snow over the winter without splitting ? If the weight of snow allows "ponding" during intermittant melts , that eventually turns to very heavy ice covered by more heavy snow. For Rye, average snowfall is supposedly 60 to up to 100" of snowfall. Steep tenting always helps & it's good to keepe expanding ice from forming in bow hatches, window frames, etc. . On the other hand it may turn out fine...
Like Sandy, I would be concerned about the bow rail. Maybe leave the tarp off the front? Good luck.
You know Sandy, my hatch doesnt leak, the more I think about it why even cover the bow and worry about the bow rails.Could this be one of thoes things that seeme to easy to be true ?? ??????????? Comments ??
Thanks as always Dino
Weight is an issue if the snow/water can not drain "off" the boat. If the snow melts, turns to water then runs into the bilge or worse freezes in your scuppers it may re-freeze. This added weight will be on the stands or trailer. I would not risk it, unless you are close to the boat and can check on it occasionally.
I couple of years ago I got tired of paying for 50’ shrink-wrap jobs to do the entire boat on had a winter cover made for the complete bridge. I have had snow & ice all over the boat and have now window, door or hatch issues.
I did that once and it made a huge pond that froze, the ice block was so heavy and slippery trying to get it over the bow rails. Need to make a pitch out of wood or PVC for it to run off.
Thats what Canvas poles are for, I have 2 adjustable poles that pushes the center of the canvas up so the rain and snow rolls off.
"Can anyone see anything adverse about building the structure over just the open aft area to protect the seats and just laying the tarp over the bow area of the boat without making the t-pee and let the snow accumulate. Cant see where it would hurt anything and would save a lot of work not building the second half of the structure."
The real question is what benefit is gained by simply laying the canvas across the bow? Seems to me it's just going to hold in moisture, and in high winds, possibly scratch your gelcoat. I would recommend some kind of structure to keep the canvas off the boat. Otherwise, it might be better just to leave the bow bare. Probably, you'll get more snow and ice accumulation on canvas than on gelcoat.
I had a canvas cover made for my fly-bridge. Boat came with a Sunbrella cover that covers the cockpit. I leave my bow (includes one hatch) uncovered and have not had any problems at all. No need to cover the bow, unless you have a leak around your bow hatch.
There is nothing better than keeping a boat out of the weather for protecting it. Especially in a freeze and thaw environment. I vote for the structure and full coverage. It is worth the effort if you want to avoid future leaks or general unnecessary wear.
I moved from Ohio to Florida this past year, and I just have to say that this discussion is causing me the most intense survivor guilt...I'm sorry I left you poor guys there to suffer..Oh well, back to the pool...
Many boats in MD are left in the water through the winter, and I'd say less than half are shrink-wrapped. We got over 90 inches of snow last year and I had no problems. I even leave my canvas up (although braced with 2x4's down the middle of the cockpit. Granted, I do shovel it off after each storm. But I don't view a boat is something to put out of sight and out of mind. If that's someone's mindset, then by all means, they should get hauled and shrink-wrapped IMHO.
Originally posted by dinows
....What do you think?
I think you are tempting fate.
If you are keeping the boat for awhile, ping Rommer. He had a custom cover built for his that will pay for itself (correct me if I'm wrong Rommer) in 4 years.
If that is not affordable, continue to do what you have been doing. The cold will not effect the portholes and hatches as much as moisture.
The best thing you can do is find a place you can store it indoors. I have a number of friends who do that with boats in the 50 foot range. I could not fathom what it cost, however, they told me with the economy what it is, indoor storage was cheaper than their slip.
My 2 cents.
I built a structure out of PVC and then throw a 60 x 40 truckers tarp over it. The tarp is going on it's 9th season and the structure has survive 96 inches of snow. At one point 28 inches had piled up. Most of the snow slides right off, but if the conditions are wrong it can build up. It's parked next to the house so I check it all the time.
http://www.facebook.com/album.php?aid=254265&id=544589143&l=5a09588164
I have a full cover for my boat. I made a support for the bow area using PVC. While it is not as steep as those who shrink wrap, it has withstood 36" of snow. I live about 1/2 hour away and usally clear it after any significant snowfall. While shrink wrap is fine, the yearly cost just keep adding up. I spent $750 on the cover; got a great deal on it. PVC tubing and fittings was probably less than $50. Cost to shink wrap about $350/yr. Payback is 2+ years but I have to do all the work. In my case
Rommer has a nice setup that is economical. I believe last year he used metal conduit and kover klamps which improved things.
This year I made a framework of EMT electrical pipe and kover klamps, something I first saw on the net and later at the Tobay Beach, Long Island, boat show. It was more difficult to do than was shown on the company's dvd (no surprise there), but basically took me an afternoon working alone. I covered it with a tarp for this season, but will sew a Sunbrella cover for it for next season. I object to shrink wrapping for a number of reasons, including cost and waste of materials, most of which are not recycled. I have never shrink wrapped a boat, used a wooden or PVC framework and tarps instead. Our daughter and son-in-law have their boat, a 34' Cruisers Cabin Cruiser, shrink wrapped, simply because they don't have the time to do otherwise. Leaving a boat completely or partially uncovered, in my opinion, is harmful to the boat. To each his own. Hy
Does anyone do their own shrinkwrap? Jamestown distributors sells everything needed and has how to videos on YouTube.
This year I have indoor storage because I have a lot of work to do but I think next year I will do my own shrinkwrap.
Thoughts?
