boat foam
I completely replaced the floor and stringers in an older 19 ft. Glastron runabout a few years ago and foamed it when done, using CG approved foam. I want to emphasize what Pascal said above - "Do NOT Refrigerate" the components. I found that warm components had apparently double or more of the expansion rate of cold - which directly affects weight, buoyancy and cost.
I came up with a system that worked well and was fun to watch.........1st, I finished the plywood covering (floor) on the stringers, then used a 4" hole saw to cut holes every 3 ft between each stringer. Save the cutouts to plug the holes later.
Jack the front of the boat as high as you can; mine was on a trailer which made this fairly easy. You want as much slope down to the back as possible and still be able to work inside.
Take 2 smaller cups - if memory serves, I used 20 oz. Pepsi cups, and fill each with one component of the foam. Pour them both into a much larger container - 60 oz or more - a cut out gallon jug works well - and stir quickly.
Now it gets fun..........as you stir the hopefully warm mix, it'll start to "grow" and start rising in the big jug. Move fast now, you won't have much time. *As soon* as it starts to expand, pour the mix into the rearmost hole and if possible use a scraper (I used strips of wooden shingles) to clean as much of the stuff off the inside of the jug as possible. As has been said - it sticks to everything and is impossible to get off. Little dribbles on the floor don't count - they're easy. You will have very little time - work very quickly.
Watch down inside the hole you just finished pouring - it's kinda neat; looks like "the return of the blob." The stuff will grow amazingly. Give it plenty of time to cure before the next batch - after the initial fast rise and apparent cure, the expansion goes on slowly for a while and can pop the floor loose. I had a few creaks, but nothing let go.
Work your way up hole by hole until done. I couldn't believe the difference in quietness of the boat in rough water and the difference in rigidity in same. Fiberglass above it and make sure it's watertight - the foam will absorb some water and I don't care what the ads say - it Will absorb some water and can be a PIA for that.
A couple of years later I built a 13 ft. Sam Devlin design duck boat (excellent design, excellent boat) and poured foam in the floatation comp'ts in the winter, under heat lamps. It almost didn't expand. It Must be warm. Hope this helps.
Lar.
Biglar. Good post. That is the way my old Formula 233F came from the factory!
Biglar, thats an awesome post! Thank you.
Let me ask you something. I had planned on doing it a different way. I was going to leave the floor out of it and pour the foam, and then cut off the extra foam. What made you put the floor in and then drill holes to pour? Thats a very interesting way of doing it..
Also, did you line the bilge with anything to leave a way for water to pass thru the bilge??
what year is your Glastron that you did this to? Mine is a 72 V182. How much foam did you have to buy for yours? ?
Thanks for the great info!
Thanks. When the foam is cured it's very hard and tough. Resilient tough. I figured that if it came above the stringers - and I'm certain now in hind sight that it would - how would you trim it exactly flush ?? Draw knife ?? Hot wire ?? I dunno, and it seemed like it'd be a heck of a job, plus you wouldn't get the adhesion to the underside of the floor. The stuff is a powerful adhesive. I just made very sure I gave it expansion room so that it wouldn't pop the floor loose.
Remember what I said about rigidity and quietness. It was absolutely amazing and I'm totally sold on it. It's very worth the effort and expense. If you're going to go to that much time and trouble, go to a little more and do it right. You won't regret it, believe me.
The transom drain was above the floor level and I sealed it carefully and completely. There should be No water under the floor - the foam Will - without question - absorb some water so keep them separated.
The boat was a 1962 Glastron runabout with a '78 Johnson 115 V4. Absolutely great and versatile combination and I loved the thing. I put nearly 700 hours on it in 6 years, mostly in Strait of Juan de Fuca out of Port Angeles, WA, but went as far as the B.C. Gulf Islands, Swiftsure Bank, Bamfield, B.C. up the west coast of Vancouver Island...........on and on. If you've seen my blog you'll know how I am about traveling. I caught 100's of Salmon out of it and many Halibut, but not many other bottom fish. The floor tore loose in rough water one day and it were a strange feeling. Felt like riding on a snake as it flexed over the waves. I did take it very easy going home, you bet. When I tore the floor out, there was no foam at all - just some rotten sticks that had been stringers. Not sure if I can find the pictures - I've moved many times since then. Many of you have seen the picture pages I make for my blog.........if I can find them I'll scan them and make a story of it.
Can't remember how much foam I used - this was in about '90 or '91 - but it was quite a bit. If memory serves it came in 2 gallon kits and I used several. On a job like this I think it would be a huge mistake to skimp on materials or quality - it's a major part of your boat and could even affect resale value.
I should mention - that boat was the original "Dustbuster," and Canadian customs in Victoria, B.C. used to laugh at the name. :-)
Lar.
v
Lar, thanks again for the info.
I spoke to a guy from the link that Pascal had posted. He told me I should need 1 quart...thats a big difference in quantities.
That glastron is a great boat, very good year, beautiful lines...
how easy is this stuff to pour and how quickly does it take to slide towards the back before expansion
Hmmm...........I think he's mistaken or not understanding something. 1 quart won't go far.
If it's nice and warm out, the mixed resins pour like medium weight oil. When you start mixing it, it just takes a few seconds before it changes color and starts to rise in the mixing container. When it starts to rise, you'd best be ready to pour 'cause it ain't waiting for you. It runs back pretty fast and rises pretty fast. I got a charge out of watching it go down hill to the back, then come right back up - like the Blob.
I worked back and forth and took my time, to let each section cure some before pouring more on top of it.
I found the pictures and they're dated from July and August, 1990 - nice, warm weather, even in Port Angeles. The pictures don't show much.......not worth scanning. Good Luck on your project.
Lar.
The common name was A/B foam when I rehabbed my Formula. The 233F took 2 gallons total at refit. 1 part A and 1 part B. No leftovers.
Agree with sealing all wood or redo the stringers with cardboard tubes cut in half and glass them in place.
As I said, when you pour the foam into a cavity it adds stability (stiffness) to all the components into which it comes in contact. I replaced some bulkheads and stringers. After epoxying the wood, then epoxying it in place, then glassing it I poured the foam into the void (compartment) making sure it contacted all the surfaces while wet and when it had expanded and cured, about 1 hour and 12 hours respectively, it made a very rigid component, moreso than the original. I was going to put the floor down first and do as Lars had done by pouring through some holes, but I wanted to limit the number of holes through the floor to a minimum. So I coated the floor plywood on both sides with epoxy, dried, coated the tops of the stringers and foam and underside of the plywood with epoxy and installed and screwed it down while wet. Then glassed it all.
The boat version of Bob villa who did a boat show ( I forgot the name of the guy, and the show <sigh> ) had a show devoted to the application of 2-part foam. I would expect that it has been u-tubed by now.
In any event, the process will progress as biglar states: quickly! So line up measured but unmixed, small batches. Have one person mix one small batch, and hand it to the "installer" who does the pour, while the first person is mixing up the next one. It is similar to a fiberglassing a large area, but it proceeds more quickly :).
Also, since the foam expands, you must provide someplace for the over-expansion to go! If I rember, in the vid, each compartment was covered, but it had 2 inch holes every foot or so. The foam was poured into the hole, then the next batch into the next hole. As the foam filled up the compartment, it foamed up out of the fill holes, and the overage was later sliced off.
I think. Hunt up the video...
