Boat Handling..
Oldgeek
Is there a specific sub-forum for boat handling issues or questions? For example I'm interested in slow speed handling with twin stern drives when docking or dealing with winds.
You are in the proper forum. Do you have a specific situation you want to know about?
Twin stern drives behave a lot more like twin outboards than they do twin inboards. The close proximity of the props, as well as there location, does not give you as great a "pivot" ability as you have with twin inboards.
In a very general sense, you need to not only factor in wind, but also current, verses the actual slip you are trying to dock to. Plan your approach out way ahead of time. Learn to use spring lines effectively (proper use of a spring line is way more effective than twin engines, or thrusters, or whatever else you want to throw in there). Do not over react, small, slow adjustments are always better than one large knee jerk reaction. Should your approach go wrong, do not try to over correct, it is always better to forget it, go back out, turn around and try again.
Finally - practice, practice, practice, and then practice some more. Slow speed maneuvering is all about practice. My experience shows me that most people simply do not want to spend a good day or two practicing.
I learned slow speed maneuvering on a 24' single engine IB when I was 14 YO. I spent 12.5 hours with my father and we did nothing else but practice docking and slow speed manuevering. Bow in, stern in, port side to, starboard side to, approach from the North, approach from the South. We went in the bay where he dropped a fender tied to a small mushroom and made me make rectangles around it keeping my position the same relative to the fender at all times. Did this forward, did this in reverse. He dropped another fender with a mushroom, and this became a make shift slip which I had to dock to, under a bazillion different conditions.
I would have rather spent the day fishing, but in the end, I became real efficient at slow speed maneuvering with one of the most difficult set ups out there.
There are books and videos on it but ultimately, ITK's method is the ONLY way. Even with book-learnin', you still have to see what works and what doesn't in different conditions, and that takes PRACTICE!
Don't let it get you down. I've been docking the same boat at the same dock roughly weekly for the past 8 years, and it STILL surprises me from time to time (it's been a long time since I broke anything though).
there's an old saying in maneuvering, "if you have to muscle the boat around with the engines you are probably doing something wrong". slowly and patiently is the ticket. it takes practice to get it just right the first try in challenging conditions, so don't let the old salts intimdate you with their skills. you'll get there with a lot less dings and agravation if you don't let it rattle your cage. before long you'll be dispensing advice here on handling yourself.
I third the motion. When I moved up to a boat with twins, I first read everythign I could and got an understanding of how it was supposed to work. I then waited for a dead calm flat day and headed out to the bay. I then spent the next 2 or 3 hours practicing slow speed maneuvers, I used a channel marker, but ITKs method is probably a lot better. But at the end of the day, I was more confortable using her at slow speed.
Also, I practice proper approaches, docking, etc, every time. DO NOT let the deck hands or fuel dock guys control you. It is your boat, you control the situation. These guys are used to chuckle heads who do not know how to handle their boat.
As was said, learn to use spring lines, they are your friend. I have pulled my boat off a dock with a 20 MPH crosswind and the current pushing me into the dock with no drama at all, not because I am some great captain, but because I know how to use my lines. Also have put her into spots that had a foot on either end plenty of times. Again, proper use of lines.
If you take the time to learn your boat you will be much happier in the long run. The time invested, at the beginning, will be returned later on in many forms. Your guests will be impressed with your ability. You will save money on repairs when you avoid bad situations. You will feel more comfortable when things start to go wrong and will make better decisions to handle those situations.
It is also not a bad idea to hire a captain to show you a few tricks and how to handle the boat.
One more thought. Someone here once said regarding slow speed maneuvers, and it helped me a ton, "only go as fast as you are comfortable running into something". Basically, slower is better.
are you trying to back into a slip or go bow in? is the prevailing current and wind usually pushing you away from the dock? if so, ask for a slip where you'll get pushed toward the dock. to minimize wind effects, drop any canvas you have (bimini's for example). also, bring your trim tabs all the way up so they don't affect close quarters maneuvering. always try to dock into the wind, if possible. it will give you much better control.
there are a few docking simulators available free on the web. with some of them you can add wind and current. it's much nicer to smash electrons on a pc that boats in your marina (don't ask how i know).
even once you're proficient on your boat, there will be some days when the winds and tides just conspire against you and it's difficult to dock the boat. in those instances, or even while you're learning, there's nothing wrong with going to the fuel dock, where it's usually easier to dock and someone is there to handle lines. they're always glad to help you take the boat back to the slip.
I have a handling question as well. I own and operate a 29' cruiser with twin 4.3L stern drives. I mostly boat in Lake St. Clair in Michigan. From time to time, when crossing the lake, I will come across evenly spaced waves that are at a slight angle to my bow. Imagine a wave whose crest runs from one o'clock to seven o'clock, and is moving in my direction. Sometimes it feels like the boat is 'trapped' in the trough of the wave, and it becomes harder to handle.
Should I adjust course and tack across the lake, or just power through? The waves are not big, one to two feet, but they are certainly annoying.
Any help is appreciated.
Oldgeek- In addition to present responses,there have been many forum discussions of this topic in the past. Here is one that might also provide a little insight including video: http://www.boatered.com/forum/topic.asp?TOPIC_ID=115532
Perhaps some links to others ...: http://www.boatered.com/forum/googl...D:9&ie=ISO-8859-1&q=docking+stern+drives#1083
danscanjr- I would steer to port to overcome the next wave at a sharper angle with better helm control then regain my original course,... repeatedly. Don't let you and the boat get trapped in an uncomfortable position relative to the seas -that will eventually set you much farther off your intended destination cross-track as the boat is consistently slid to port, and lets the waves take necessary control from you.
Wow! Lots of great suggestions and help. We had a 26ft single for several years and had handling that down pretty well. We moved up to a 33ft twin stern drives and have discovered that handling it is a little different. Thanks to everyone for all the great suggestions and links. We do most of our boating on the Rideau River here in Canada so we don't see much open water or severe weather, however we do have to contend with winds and currents. We also have a number of locks that must be negotiated to go anywhere so often contend with slow speed maneuvering often in a wind. All and all I think the points made about practice, (and more practice), and the fact that somedays it just all goes away on you, are important ones. I'll be checking out those links as well. So thanks again to everyone!
Sandy - checked out those videos and links....I have seen the "Pivot" video before and found it pretty interesting. I also found the bit about "walking" the boat sideways as described in one of the links interesting as well. I have actually seen someone do this and it is pretty impressive to see. Thanks for sharing those...much appreciated.
Regards...Bob
Well I had my 1st major docking screw up today. I must have dropped one of the large 7/8ths stern lines in the water. I had one of the spring lines on the and the starboard aft line on but was pinned against the dock the bow thruster would not do anything. At that point I should have shut down we were secure but I wanted the bow line on. It just so happens I misplaced the port aft cleat line and it wrapped up in my shaft and stalled the motor literally throwing me out of my seat. Once I shut everything down it was obvious what happened. Note to self when things don't seem right and you are secure shut down. I had to cut the port aft line and it sounded like a piano string snapping. Then the bow walked right around. This is the 1st mishap in 4 years of docking. Tomorrow I will get a quick haul out and see if there is any shaft damage. I feel like a ja*ka*s. Lesson learned when it doesn't seem right stop everything. Bill
Point is you are human, experienced, and sh-t still happens. A day without learning something new is a wasted day.
Trust me. Next time you suck up a line, you will kill the engine quicker. Might not make any difference however. Don't ask how I know this... ;)
In boating, many things need to be done correctly the first time. That's just how it is. And most of us have learned by trial and cussing error.
Bill, I saw a dock mate one day cut a 12" gash into his swim platform when a dockline got tangled in his prop. It is amazing how strong dock lines are. His line cut through the fiberglass and wood like butter. Screwed his motor also.
In boating, Experience = Humility. I was so embarrassed the first time I ran aground. But now I realize that bad stuff is going to happen from time to time, even to good captains. I only feel bad if I was being arrogant or stupid. It is one thing to have a hard time getting your boat into a small slip in a strong cross wind with an akward current. It is another to have trouble going way too fast, and not being prepared with the right plan and lines out. Sometiemes your best just isn't good enough, sometimes it just isn't your best..
Nothing like some unexpected single-engine practice....
I've found that backing against a stern spring line will pull the bow away from the dock (almost like a bow thruster only cheaper)... Then all you have to do is throw the line off and go ahead. Works like a charm on my old single-screw kite.
Whin I was learning, and am still learning 7 years later, to put our 24' deckboat into its slip my wife called it the dingy because of all the small dings I was putting in it. As they all said it simply takes practice and more practice. I swallowed what little pride I had left and asked for help here. After practicing the advice from this forum....no more dings. Heading to the lake tomorrow and since we have only had the boat out once this year I'll spend an hour or two practing docking to get the skill somewhat back after a Winter layoff.
The only solution to close quarters handling is experience and lots of practice and even then stuff will happen. When you are in easy conditions (little wind or current) you have the benefit of being able to make a mistake (i.e. port engine in forward when it should have been reverse) and you can correct and still get into the slip without having to start over. When conditions are not in your favor and you make even one mistake chances are you are not going to be able to salvage your approach. The experience will teach you to just start over and not make bad conditions worse by trying to salvage your error.
In the end Mark summed it up very well "Sometime your best just isn't good enough, sometimes it just isn't your best..." Unfortunately sometimes the only way we learn things is when it just isn't our best. We have all been there and all you can do it hope that you learn something. That is where the experience comes from and unfortunately you can't get that from a book or online forum.
Kris
