Boat Leak Somewhere
Steppingstone
I have a 1986 Sea Ray Sundancer that I just put in new carpet and somehow it has a wet spot toward the V. Now when I had the carpet out for a week it did not exhibit and signs of water coming from the floor. I did notice on the side windows that the caulking needed to be replaced
which I did. It has not rained since, but what is weird is that I cannot feel where this came down the walls or where it is coming from. When I did feel it, it rained the night before. This
boat sits on a lift. My question, is it possible for a hull to crack or do you think it is a leak from the windows having gaps in the caulk that made it's way to the floor somehow without any other indications of a water leak?
This is very frustrating just putting in new carpet and I see a wet spot already.
Any advice would be greatly appreciated.
Stone-I would reseal those windows, you might also check if there is a hatch above the spot that might be leaking.
One of the first places to look whenever you have water in your bilge is the fresh water tank. Sometimes those develop small leaks and leave people to wonder where the water is coming from.
Last year I had a leak that seemed to be coming from one of my cabin windows. I discovered that the screws on the center hatch had vibrated loose. After I tightened them, I no longer had a drip at the cabin window. The water was coming in at the hatch and running over to the window where it would gather and drip.
One way to find a leak is to cover an area with baby powder. The water will leave a trail through the powder. Then you can vacuum up the powder after you have the leak identified.
Check the rubrail. I had to remove mine, rejoin the hull to deck joint (5200) and remount the rubrail.
Was going to suggest chalk but Liz beat me to it with the talc idea. Sundancers have a thing for wet carpets. Smell it and taste it (in that order!!! May be a holding tank leak), saltwater will be easier to pinpoint. Freshwater can be your freshwater tank, leaky window, leaky hatch, leaky door, leaky (name your through-deck or through-bulkhead fitting). Use chalk or talc. Chalk is less likely to run off with the first hint of condensate.
If foward of the V in your boat means up near the bow where sleeping v berths can often be?? How about checking the bitor something on the top of the cabin right above the wet area. I know what the window gaskets gaps look like but can't imagine wetness in only that one spot. High bilge water level should be obvious if that is the problem.
Something similar happened to us. We have a 1990 Sundancer 310. The carpet was damp. There was no obvious "spot" in the floor where it was coming in. (I sprinkled flour on the floor after pulling back the carpet to get the general area it was coming from.)It was like it was seeping through the fiberglass. After putting it on a service rack and looking my husband found a crack in the hull. It was from age and the forklift pressure. The previous owner thought it was a window leak too. Fiberglass repair is complete and we used the boat all weekend with no more problems. This was a perplexing problem b/c my husband had been convinced that it was the window...now I get new carpet!!!
i dont' understand how carpet can get wet and you dont' have any water accumulating in the bilge...
fiberglass hulls should not crack from age... especially after only 17 years... what will happen at 250 ?
as to the original question, if the boat is stored on teh lift, you can eliminate water coming from the hull.. take a hose and spray the top to make sure it's not a leak from a hatch... also keep in mind water can come in higher up and flow under until it meets something to make it drip...
then spray aroudn the rub rail and porthole. take your time and make sure you soak each area thoroughly, inspect, then wet another spot.
I agree. I asked my husband why there was no water in the bilge.
He said it was b/c of where "our crack" (ha!) was located. It was where the interior floor joined the hull. These areas are, from what I understand, fiberglassed together, almost like a seam. If it had been anywhere else or larger than it was...there would have been excess water in the bilge.
Then I threw out there the fact that it shouldn't have cracked after 17 yrs.
He went on to say that he was no expert but it was more than likely from being blocked up incorrectly last year when the prev. owner had the bottom repainted.
I had him nice and irritated by now and I didn't point out that all this could have been avoided with a professional survey prior to purchase! Oh well. It's fixed now and I hope that was the worst of our suprises!
Thanks!
