Boat lift remote control
rockyrr
I'm having a Magnum 10,000 lb boat lift installed. I'm considering adding their remote control option. Does any forum member wish to comment on the advantages/disadvantages? Anybody have a remote on their lift?
When we first bought our boat I stored it on a neighbors lift while mine was being installed.
A really nice gesture of my neighbor!
His did not have a remote - imagine this: When we would leave - I had to lower the lift, get on the boat once it started to float and take of - no huge deal, other than the fact that sometimes I did not lower it enough and my extra 200 pounds made emough difference for me to have to lower it just a bit more.
Returning was the pain - since the tide had changed I had to approach the dock, get off the boat, position the lift, either pull it on or leave and return. When the boat was in the slip, get off the boat and lift it out of the water.
TODAY - Leaving - we get on the boat, lower the boat into the water (while in the boat via remote) and leave.
Returning - I have some electrical tape wrapped on one of the guides that indicates when the lift is at the perfect height.
If the tape is under water I just drive right on - if the lift needs to be lowered - I simply do so by remote, then drive on.
The best part is that once we are in the slip, I lift the boat (by remote) enough to keep it from floating away, cut off 1 engine, raise the engine hatch, plug in the fresh water to the remaining running engine and raise the boat all the way out of the water while never stepping off the boat.
The family gets off I clean the boat.
Do you still have the choice of installing a bigger lift? If so I would opt for the 16,000 - not much price difference and the ability to upgrade!
We love our remote. At our condo the rules state that once you leave the lift it should be raised to help prevent damage to the slips and dock from waves banging them around under water. With a remote that's simple to do.
I don't have it and wish I did. Where we are, an unusually low tide prevents us from launching or recovering. If we aren't careful, we can "overlower" the lift and the cables come unrolled. Many of the remotes incorporate a counter or limiter to prevent that. Same feature prevents "overlift" also.
Thanks for the feedback, folks. Looks like I'm going for the remote. Shep, probably a good idea about a 16K lift, but our 10K is now being installed.
oh well, hindsight, We bought our 248 in July of '05 had a 10k installed.
We bought our 298 in Aug '06 - a 13k could've done it - we figure the "2 foot itis" may strike againand went with a 16k!
