boat name lettering
reinbilt
There seems to be a lot of online companies that offer custom lettering for boats. I'm sure many of you have used them. Were the results what you expected? If applied properly does it look like a professional job? The cost seems a fraction of what a sign shop would charge.
Find a reputable small local sign shop. You don't know what you are getting from the on-line co's. There are many diffrent grades of vinyl and they will all look the same when new. In addition, the application can be difficult if you have never done it before, one wrinkle is all it takes and it looks like (you) did it.
You can also go to boat/us.com and see your boat name in a large number of fonts and sizes. If you wish you can order from them or simply note the font and size and take that to a local sign shop.
And, if you don't want to end up with one of your legs under the lettering when finished, sometimes a local sign shop can install it too.
I've had several made locally by a sign shop and have put them on myself. Saved a lot of money with great results.
I second the local sign shop ... they can do almost anything .... I wanted gold leaf for my old CC ... they did a great job that I installed myself for about 1/2 of what most internet companies wanted ... then they made the registration numbers as well.
Thanks for all the input. A good thing about using a sign shop would be making sure the color is right. The online places really don't offer a large selection and who knows what the end product would look like. Good point about the quality of vinyl. Thanks again
You get what you pay for. I have always used local shops. If there is a problem they will correct it. Also they will show you how to apply. Get the best grade vinly. Cheap stuff can be $18 a 100 foot roll, the very best over $500 a roll! The cheap stuff will last a summer or two--the expensive decades.
Also, if you are there , they can show you exactly what it will look like in any script or color you want, on thier computer.
i've used on-line places twice and haven;t had any problems. the first has ben on for 4 seasons. the second for one (so far).
I have had good luck applying the letters myself after ordering them from the Internet. I have done it on two boats. I also had sample colors sent to me so that I was sure what it would look like. They are easy to apply because you squirt a soap solution on the surface first so that you have the opportunity to correctly position the lettering. Once it’s right, you squeegee it out and let it dry. They have very specific instructions and I had never done it before.
I don't know a lot about boating...but I do know about vinyl lettering. I've owned and operated a vinyl sign shop for 19 years and have cut ready-to-apply vinyl lettering for a lot of boat owners. A local sign shop is the best source (as opposed to internet sources) because we can show you how to apply the graphics in a few minutes. I usually give the customer some scrap vinyl letters to practice with. They can apply it on the boat surface and get a feel for the process. If the test graphic is on only a few minutes you can peel it right off, re-wipe the surface with alcohol and then proceed in applying the real lettering. The soap and water method is fine, as long as you use one or two drops of liquid dishwashing detergent in a 32 ounce spray bottle. This trace amount of soap will break the surface tension of water and allow you to easily squeegee the liquid from under the vinyl. Now the adhesive will bond to the surface and it will stay until you want to remove it. Too much soap and the bond is compromised. Don't sweat an occasional bubble, the small ones will "gas" out in time, larger ones can be pricked with a pin and the air/liquid is released..just press down with you finger and they're gone. Before you go to the sign shop...measure the rectangular area you want the lettering to fit (avoiding hardware and body seams) The sign shop will adjust the graphics to fit in this space. Don't settle for a boring font...but don't waste a bunch of time going through the thousands that are available. Arched text can take up a lot of space especially when the name is real long.
It's sad to see a beautiful and expensive boat with hardware store looking registration numbers. A sign guy can make these look nice for under $50. Feel free to email me if you have questions.
Good post Eaglegph. Those are the reasons I always buy vinyl graphics locally. Also, they can show me exactly how it will look on the computer screens in various fonts, colors and styles before they cut any vinyl.
I have used Boat US and another web site graphics place in the past as well as the local sign shop. The boatUS lettering was a single color and looked fine. The other place, we decided to go two colors, but the black was merely sprayed on and didn't last. The first waxing took the black paint off the letters. The local sign shop was by far the best quality and the best price. When we have to do it again, it will be the local guy
My local sign shop gave me I believe a really good deal. Their price was $110.00 for the name, LAKE EFFECT, in 6 inch gold lettering with black outline plus the hailing port in smaller black letters plus they will install after I prep the surface. They were upfront about the vinyl quality, 10 years.
My local sign shop also printed the name on banner paper so I could tape it on and step back for a real preview.
Aftre I did this, I realized our plan wan't going to work until we reduced the font size. I highly suggest this if you can.
You can also do this on your home printer by selecting the "Print-Poster" option if you have that. Most do. You'll just have to tape it together.
Mine has been on since 1993, WEATHER OR KNOT. Done in teal with black shadow. The shadow was part of the finished effect; did not have to place teal letters over black shadow.....it was all one piece. I also had it done on paper first to see how size & font would look. Made a couple minor changes before the finished choice. Tape in place & if very large like mine was; I did it in 3 or 4 segments. Came out perfect. Just take your time & get all air bubbles out.
