Boat Opinions
SteveR
Ok, posted this on the Sea Ray forum and got no replies so I'll try here. I'm looking to buy a 2000 Sea Ray 260 Overnighter with a Mag 454 385hp Bravo 1 and the corsa exhaust. Boat has pretty low hours and looks to be in great shape. Anything I should look out for with this powerplant? Boat itself? Risers & Manifolds haven't been changed out in a while so since I was going to change them, I thought I'd go with a GIL exhaust system.
Yes, invest in getting a good boat surveyor. Make sure you have a sea trial. Only then after you get the reports back and you watch the surveyor you can have some piece of mind. Bill
The guy is asking for some inside information on this make and model, yet he gets the standard "get a survey" answer. I'm sure he has the intelligence to have it surveyed.
"Get a survey" seems to be the blanket answer when someone doesn't have a clue about the subject matter at hand.
Not true Barq. A survey let's you know what to expect from the boat and protects a sometimes LARGE investment. I agree with BillyIII on this one. Other than not personally knowing THIS particular boat, it is the best info that one could give. I am sure there will be others along that will give info on the same type of boat that they own with their own experiences.
I also agree,
There have been some long term RO's that even with all the "standard "get a survey" answers" still have not gotten a survey and have been bitten in the A$$ because of it
Well, one thing is for sure, YOU have no clue about the "subject matter at hand" and certainly added absolutely nothing to this discussion.
A lot of people don't even know that there is such a thing as a "survey". Each boat is different, it takes a qualified person to examine each one for potential problems.
The 260 is a nice boat and that is more than enough power to run it. There are several at marinas in my area but I have never seen one with that particular engine and exhaust setup. Is that a custom job? If so, was there a necessity for any reinforcement to the stringer system added to handle the arrangement. If there was, was it done? If it was done, was it done right.
The Sea Ray site should have the documentation as to the options available for that model boat. They do for Saint Max as well as many others.
Do you intend to use the boat as a second home or as a day cruiser with the occasional overnight? I ask because if you intend to use it as a second home, a 260 (any 260 type boat) will get small quckly and you may want to consider a larger boat. The market is ripe for great deals.
I think Harlan used to have a 260. He went everywhere in it.
From the Powerboat Guide dot com site, these were the models and the years produced.
The entire Guide is available (download) for about $45. and includes the specs of each model and a brief description of the performance and or opinions of the reviewer:
Sea Ray 260 Bowrider (1996–2001)
Sea Ray 260 Bowrider Select (1998–2001)
Sea Ray 260 Cuddy (1989–91)
Sea Ray 260 Overnighter (1989–91)
Sea Ray 260 Overnighter (1999–2001)
Sea Ray 260 Sundancer (1999–2002)
Sea Ray 260 Sundancer (2003–04)
Sea Ray 260 Sundancer (2005–Current)
Sea Ray 270 Amberjack (2005–Current)
Sea Ray 270 Select EX (2005–Current)
Sea Ray 270 Sundancer (1992–93)
Sea Ray 270 Sundancer (1994–97; 1999)
Sea Ray 270 Sundancer (1998–2001)
Sea Ray 270 Sundeck (2002–07)
Sea Ray 270 Weekender (1992–93)
I have been on several 260 Sundancers, but never the Overnighter. Not sure of the differences. I can say the Sundancer makes for a respectable weekend/overnight vessel, but probably will not have a generator (for in the cove AC).
Be aware that the Mag 454 loves fuel,,,
Fred
Originally posted by Shadowcruzr
But it's a SeaRay...caviet emptor...
The same could be said of any boat to include the Bertram that delaminated underway and dare I say it....I dare...A Chap?
Yes you could say it about them all. It's just fun to pick on the SeaRay crowd.
The OP was asking about specifics pertaining to a particular model boat. He didn't ask for someone to go examine the boat.
And most people in boating know about surveys. Too many on here like to answer with "get a survey!" instead of offering advice.
Guess according to you the various magazines that do boat reviews should stop and just write "Get a survey!" instead of offering a review for potential buyers.
I'm moving up from a Sea Ray 215 Express Cruiser (Weekender) that I bought a few years ago and yes I had a survey done when I bought it. This one will be a little more $$$ so if I decide to go through with it I'll get a survey done on it as well. The Mag454 w/Corsa is a factory option from Sea Ray. You could also get the std 454 mated to a BIII but that one is rated at 310hp. Just figured if anyone was familiar with this set-up maybe they would recall if there were any known issues like having to lift the motor out to change the oil filter and such. The reason I'm opting for this over a cruiser is my wife wouldn't sleep overnight on a bet so it's day trips only. I'm not a speed freak but it would nice to cruise at 35 - 40 rather than 25 - 30.
