boat power question for engineers.
Thudpucker
The question is:
What engineering (factualy)parameters would be used to decide on whether an outboard or I/O would be picked for a propulsion source?
So a young boat company or even an old establishement is about to launch a new 22' hull in several varieties.
Our choices are 250hp single outboard, and a 250hp single inboard.
The sales folks would like one or the other for marketability reasons. The Bean counters might have an opinion as well because cost determines profitability.
But the Engineers will have the 'Logical' reasons for the one as opposed to the other one. The real facts of the matter.
What are those reasons?
My engineer friends say reliability is equal to the number of moving parts. The fewer moving parts, the better the reliability. Based on that assumption, I think the OB may be a better choice.......
Thats good reasoning Liz.
Probably is one of the Engineers parameters as well.
Another engineer told me that we should always go with one engine if you can get the HP you need, as opposed to two.
There must be other reasons. We probably have heard each one of them at different times on this forum. Each expressed in differnt ways.
But.... I wanted to hear them again, in capsule form.
Direct drive inboards are the least efficient from a speed and economy standpoint despite many advantages. rear engines provide the best interior space and regardless of any other feature it is interior space that sells boats. So you see it is not an engineering decision after all.
Given some outboards are actually V6 4 strokes, with superchargers, I don't see how they can have less moving parts. Check out Mercury's Verado.
Is this discussion centered on a single inboard or a single i/o vs. the outboard? The performance of the i/o is comparable to that of the outboard from a drag point of view. With the newer generation 2 strokes and 4 stroke outboards the pollution side of the equation is getting much better.
On equal hulls, a 2-stroke DFI outboard will run off and hide from an equal HP I/O. And the DFI outboard will probably burn less fuel, will run cleaner and be quieter. Proper maintenance of course is critical on any marine engine, but a DFI outboardshould easily run 1,000 hours. And the outboard is outside the boat so you have full interior space. The outboard, mounted on an adjustable, even hydraulic adjustable, mount like a jackplate allows the "X Dimension", or mounting height to be easily tweaked for max performance in different conditions and different loads.
The OB is so far superior it should not even be discussed. Stern drives are for those that don't want max performance from their rig.
gaineso, doing maintenance at sea upon a bracket mounted O/B is NOT convenient, esp when compared to an inboard. Raw unadulterated performance is not the sole criteria upon which one makes an engine decision. As with most decisions related to boats, the engine decision represents a compromise.
O/B's can be great but they can raise the COB which might be important. O/B's do not take a dunking very well, so if rapid backing down is needed, an O/B ain't it. ( For that matter, O/B's often back badly. ) An I/O is a good choice for when you want features you cannot get on an O/B, such as an engine heated water heater, or, perhaps, an oversized alternator. And you can maintain it from within the hull. YOu can also easily trailer it, as well as explore the shallows ( similar to the O/B ).
Straight Inboards are great. Maintenance is just plain easy ( esp if you have a roomy engine room ). They are often quieter. The forward COB makes for a different ride, which some consider important. And the rear cockpit is open and unencumbered as is the area just outside the hull. Fishing from an inboard is really, really nice.
Each has it's place. YMMV. Imho.
22x what? what does the bottom look like? how about,,, where does the weight belong? is the transom designed to hold more than 1 ob? is there an estamated hull speed?
Gaineso may argue all he wants for 2stoke but they are obsolete
Scott, Its a hypothetical question designed to get to the reasons for doing it one way, as opposed to another. If your resoning demands a size, and W&B statment, make one up and say why. That's what I'm looking for, the reasons!
Bruce, alas you are correct. The Engineers provide the truth and the basic table to work from. Always, Sales has it's way. (I think the industry knows that Sales people are the Hero's that keep the smoke stacks puffing)
In the board room there would be models of each type, made by the engineers.
Probably that board room has been replaced by today's standards as the models would be 'Sketchup' 3-D animated diagrams the folks would be seeing it on their laptops.
I helped convert an Aluminum boat from a Chevvy V-8 outdrive to twin outboards.
The weight loss difference alone was a winner. The room in the back deck was another winner, the 'well' where the old engine had been was converted to a fuel tank that held 19 Gallons which really extended the range.
If I had my druthers and if I'd ever have another 20-25 foot boat, it would be outboards.
In salt water these newer outboards seem to corrode to death. I think if I had some influence with Engineers designing a new outboard, I'd make everything attatched to the block with a thru-Bolt/nut.
Simply from a visual selling point, the OB gives you more room. Then there are the Pacific Northwest style boats like the 22' Orca which is positively huge for it's size and the IO is below decks.(at least I think it was a 22')[:I]
I'd have to give the edge to the OB in the average 22' boat.
Thud, I still believe that a large portion of the design decision revolves around the intended purpose of the boat. In this particular example ( a 22 ft -ish boat ) a straight inboard is inappropriate for most purposes. ( one exception: small shrimpers use inboards as the like the large open cockpit and unimpeded access over the transom. ) The I/O is a compromise ( always has been ). I know that if I were looking at a sub 25 ft boat I would be discussing O/B and nothing else. But the weight difference ( vs I/O ) is not that large, and since an I/O is closer to the COB than a bracketed O/B, the weight difference begins to be a non-issue. The choice is between a "clean" transom and a lost area in the cockpit ( if a low deck. If the deck is high w/ engine below then no diff. )
One of the "nicer" features of an O/B is the ability to lift off the existing power package and replace with the powerplant(s) de jour. Want more power? Just drop off those twin 150's and strap on a pair of 300hp Vorados. Voila! You can't do that easily with any inboard powerplant.
So we are back to the decision making. In sub 25' range, O/B. In the over 35ft range, inboards ( due to the need for large engines ). In between, just grab dem dice and roll em. You will need to choose based on the specified usage.
This process should get interesting if they ever crowbar a 4cycle diesel into an O/B package... ;)
What never came up, and lay people (We experienced users) wouldn't consider is the Hull strength at the different frame members to support Torque and resist flex.
Remember that Drug bust photo of the big open deck cruiser with Six huge outboards?
That boat would have an awful tendency to buckle the sides of the structure outwards at the top edges when you floated over the top of a wave and slammed into the trough. Not to mention what might happen just in front of the Transom if you slammed all six throttles at the same time.
And you mentioned discarding the (this Hypothetical boat is a Single engine job) 150hp outboard and dropping on the 300 Verado. Would our engineers have to provide for those levels of stress?
On a little single engine boat you would have the same consideration, just not as severe.
I/O's have the engine timbers to carry the weight of a dive into a trough.
Torque is another problem with Hi horsepower. The old 'Equal and opposite forces' trying to turn the boat over using the force against the prop, problem. Somethings gotta give there. We hope its not the middle of the boat.
We all know about these things, we just wouldn't think of them in an Engineers terms.
At one time I had the idea of using an Inboard engine, mid-cabin installation, and coupleing that to an I/O drive in the Transome. Using Automotive Drive shafts and Universal joints.
That Idea has some merit for several reasons. However not enough to attract investors though.
Hey, whats that laughter I hear in the background????
Actually, in outboards, especially in higher HP brackets, the 4-stroke is a dieing dinosaur. Heavy, dirty, noisy and thirsty, at least compared to the latest 2-stroke Opti, HPDI and E-Tec offerings.
As far as backing down in a hurry, not much problem with a properly designed OB rig. If the motor is going to get so wet it dies, then an I/O propably be taking green water over the transom. I have seen way to many outboards take a backing wave across the top of the cowling without missing a beat.
It all depends on the design and application. But for smaller boats, outboards rule and probably always will and 2-stroke DFIs will rule outboards for many years into the future.
"Actually, in outboards, especially in higher HP brackets, the 4-stroke is a dieing dinosaur. Heavy, dirty, noisy and thirsty, at least compared to the latest 2-stroke Opti, HPDI and E-Tec offerings. "
I thought it was the 2-stroke that was the dinasaur???
The outboard must be winning the sales/engineering battle. At least we are seeing more and more outboards on larger and larger hulls.
G
have you seen the intrepid 47 - all outboards. According to them it is a performance thing - faster than if they put in $100k of yanmars ???????????? yeah I dont get it either on huge heavy boats.
Thud
On a 22'er the adv and disadv are to clear. When you get to 30-34' the debated gets more interesting.
I think the outboard is winning. In the "Mine is bigger than yours" game a 275hp outboard sitting on the transom (or three of them) is pretty explicit. I also think they're safer (less boom factor).
The most powerful and efficient piston engines are 2-stroke diesels; but (so far) most of them won't fit in/on the average pleasure boat.
2-stroke has a lot of things going for it; now that the manufacturers have gotten off their hands and addressed the pollution and fuel consumption issues.
i'm not an engineer but stayed at a Holliday Inn express last night...
i dont' see a very important issue mentioned : how will the boat be used.
for cruising, hanging out at the back of the boat, swimming, relaxing, do you really want to have a couple of motors in your way ? I don't.
that's why so expresses are mostly IO then inboards/vee drive as they get bigger.
If you keep the boat in a slip with no finger pier, outboards are a PIB. you have to go in bow in which makes boarding and loading very insteresting.
For fishing, i dont' see how outboards in the way make sense, at least for offshore fishing.
bottom line, i think there are very few engineering parameters to decide one way or the other... it's neither an engineer or bean counter decision but a sales / market / target decision.
for instance, if power is key like we see in so many 30ish footers with 1000hp, outboards are the only way to go since cramming that HP in a narrow hull is nearly impossible without killing interior space.
then of course as Willie said, there is the appeal of flashing your HP to the rest of the world... and judging by the loud music and attitude of some owners i wonder if the need for something big hanging back there isn't making up for something not so big hanging down there :-)
I dont want to try and predict the future. I just wanted to know the rules/paramaters that bring forth the decision of the One or the other one.
Willie's right, Outboards it will be on the smaller boats.
Fishing over an outboard is not too bad of a deal. I've done it most of my life.
The one absolute benefit of an inboard was the warm cabin heat in the winter. Man you just cant beat a warm place to be when the weather is snarling outside. Huh? What noise?
