boat slip size
DaBoatChick
Is it a bad thing to put a 24' boat into a 35' slip to keep for the summer season? What could happen between low and high tides? Thank you
Help! I have a similar problem as the quote below. I have spring lines to protect my stern from the dock. The problem is during a storm one would have to go aboard to adjust the lines during bad weather. Trying to come up with a way adjust those lines from the dock.
Originally posted by Veebyes
Much better to have a slip too big than one too small like this one. The mooring methods are the same. I was just borrowing this on for a few nights. The boat is too big for the slip but the slip owner has a neat system to keep the boat away from the dock & centered in the slip no matter the tide.
The lines on the mid spring cleats go through a pulley & into the water. At the end of them are weights which keep tension on the line no matter the tide. To board the boat, just pull the stern lines, which also always tension because of the weights, & the boat comes back.
You guys back east have it a lot tougher then we in California. As far as I know, all the docks in the delta and bay area have floating fingers on both sides of the boat. I keep my 22 ft + pulpit in a 30 ft slip. I'm paying a little extra, but it is worth it to me for many other advantages of this small marina. The slip is 11 ft wide and my boat is 9 ft wide. When I leave the boat, it is tied on four points centered in the slip. Plenty of wiggle room for winds and/or storm surge.
When I arrive at the boat, I undo the two on the stbd side. I have "cup hooks" that I hook the end of the line to to keep it off the dock and out of the water. On the port side, I pull the boat snug against the finger and retie so that boat is held in place. This allows me easy access and boarding.
