It will protect the gelcoat from moisture, but you also need to protect it from fouling. Yes, you can do that manually if you are willing to commit to doing this several times a month. If you just clean the hull once or twice a season, you will greatly affect your fuel usage and speed. A clean hull is the most efficient however you choose to obtain that.
I had the barrier coat put on, then the antifouling coat and then I only had to pull the boat and power wash it two or three times a year. Now, I keep it on a lift when I'm not at the boat and only have to occasionally clean the waterline.
